Originally Posted by Snagglefoot
Someone say Pennzoil Platinum Euro 5w-40? " Exceeds Maserati"
Originally Posted by avacado11
I've seen some euro oils at Walmart. Just need to figure out an alternative incase I can't get Pennzoil.
Just order online at walmart.com, and ship-to-your-local-store for pickup later.
https://www.walmart.com/nco/6-pack-Pennzoil-Platinum-Euro-5W-40-Motor-Oil-1-qt/754837377
... or, Advance Autoparts should be able to ship it in to their store or to your door via the internet.
Probably your best bet since its by a reputable experienced company, and its the exact specs your car calls for, and its got the prancing horse recommendation printed right on the label, a direct hit !
Would it make sense to run something like Royal purple 5W40 or M1 Advanced with 6k intervals or just a waste of oil?
Mobil 1 0w40 at walmart would work well. Royal Purple would be basically OK too, yet that is nothing special, and it normally costs a lot (marketing it with purple dye seems to entice some sheeple....).
You certainly can get creative, knowing the ACEA A3/B4 spec is met with a lot of 0w40 and 5w40 oils in existence.
I'd tend to favor a VW 504 oil in your application, such as Mobil 1 ESP 5w30 with HTHS 3.5, right for your engine, would work with the new low-sulfur gasoline we finally have in the U.S. About the VW 504, Lubrizol says it is a little tougher spec to meet than the other German specs, so follow that
504 and you'll be fine.
https://online.lubrizol.com/relperftool/pc.html
