I own a 98 Intrepid. The have a host of issues. From the Catalytic Converter being right up next to the side of the engine, this doesn't help keep the engine cool, plus the Cat. is cooking the oil on the passenger side, which is where the oil returns to the sump. It's best to go full synthetic and have a lot less headache and worry's. Do change the coolant as it was stated in prior post, make sure you have the correct thermostat in the car. Clean PCV often, especially if it's is old design. Water Pump is a huge issue on this car, replaced mine already at 75,000 miles, it started leaking out of the weep holes. This is a big job to change the water pump( remove intake, valve cover, pully's, front engine cover), cost can be up $750 to $1000 or more dollars, because in that engine you don't simply want to change the pump, you want to do the timing chain, tensioners also. If I where you I try to find a different car, but if that is all you can get right now, be warned, the car can be high maintenance.
