Yep. Quaker State Full Synthetic 5w30 is all SQ at several Walmarts I frequent.Im curious...looked on Amazon...looked in the local Walmart... The new formula is probably in the bottles but I dont see any bottle which says SQ...
This is not directed at you, but in general. How can API SQ improve on SP’s LSPI protection in the real world? Even on this massive board, with people laser-focused on everything oil-related, and also willing to blame the oil in many instances where it was not even a factor, I don’t think I’ve seen one single person who knows of an LSPI event that has destroyed an engine. Not even their neighbor’s cousin’s auntie’s grandson’s baby mama…
- Overall, API SQ improves upon API SP with enhanced protection against LSPI, better timing chain wear control, support for ultra-low viscosity oils, and stricter emission and cleanliness controls. These advancements help meet the needs of modern engines, contributing to improved fuel economy, lower emissions, and longer engine life.
Yep, myself and others owned TDI vehicles before we even had SN Plus … don’t get me wrong - they all brought in a better balance of calcium/magnesium - things to quench - but there is likely more to the story on failure events …This is not directed at you, but in general. How can API SQ improve on SP’s LSPI protection in the real world? Even on this massive board, with people laser-focused on everything oil-related, and also willing to blame the oil in many instances where it was not even a factor, I don’t think I’ve seen one single person who knows of an LSPI event that has destroyed an engine. Not even their neighbor’s cousin’s auntie’s grandson’s baby mama…
About the only way it’s possible to induce the conditions is to have a small turbo engine that’s ingesting quantities of oil vapor into the combustion chamber, lock the trans in manual mode (if it even has one), put it in waaay too high of a gear (sub-2k RPM), and then tow something up thru the Eisenhower Tunnel with the pedal on the floor. I’d love to see manufacturer-accepted or even SAE data that shows the failure rates due to LSPI vs the total population of engines they say are vulnerable to it. I bet there’s not only quite a few zeros between the decimal and first number, but also that the majority of those engines were likely neglected as well prior to their demise.
BTW, H/K engine bombs and YT videos don’t count since they’re not verifiable![]()
All of those are addressed in AP SP except maybe the vague ""updated and more rigorous engine tests". SN+ was the first API standard to address LSPI for example, and ultra low viscosity support emerged with GF-6A and GF-6B.Brief overview about API SQ for those not in the know {quote from Google }
Engine technology has advanced rapidly, leading to different lubrication needs than in the past. The API SQ standard, launched on March 31, 2025, is the latest specification, succeeding API SP.
API SQ offers several advantages over API SP for modern engines:
- LSPI Protection: API SQ addresses Low-Speed Pre-Ignition (LSPI), an issue that can damage turbocharged engines.
- Timing Chain Wear Control: API SQ oils use optimized additives to reduce timing chain wear and extend engine life.
- Ultra-Low Viscosity Support: API SQ supports SAE 0W-8 and SAE 0W-12 grades, which improve fuel efficiency.
- Emission Compliance: The standard limits sulfated ash content to 0.9% by mass, which helps protect Gasoline Particulate Filters (GPFs) and reduce particulate emissions.
- Engine Testing: API SQ includes updated and more rigorous engine tests for better performance assurance.
This is why we don't go with "AI" answers.
Going by Infineum, it was Ford and GM that approached them about determining the causes of LSPI in the North American market, and finding solutions, as both marques were planning on introducing small TGDI engines that were likely to suffer from the phenomena:As I understand it, Toyota found that LSPI, caused by oil, was damaging engines, which started the oil evolution to control the event. I don't think they made this up. And Toyota isn't big on turbos, at least in the US market. Anyway, I'm curious what chemical changes are in SQ. Even more Calcium reduction? And what additive to reduce cam chain wear? Moly?
Well, let's compare:Complaint registered. Question remains: what's new about SQ?
https://www.infineuminsight.com/en-gb/articles/investigating-low-speed-pre-ignition/
Infineum said they knew about it since 2007.It's my understanding is that Toyota is the first company to discover that oil was contributing to the problem, and they published a paper to that effect Toyota’s SAE 2013-01-2569
Is this wrong? I don't know. I came to learn this on this forum, though.
What took them so long? SP was released in 2020.Infineum said they knew about it since 2007.
The SWRI consortium, launched in 2010, was looking into oil, and fuel, as contributing factors and already working on mitigation strategies, as detailed here in 2010:
https://www.greencarcongress.com/2010/10/p3-20101007.html
Perhaps Toyota was the first company in Asia to be working on this?
SN+ (2017) was the first API category to address LSPI, but yes, it took them ages to develop a reliable test for it.What took them so long? SP was released in 2020.
VW knew about it in mid 2000. EA113 1.4 TSFI engine with both turbo and supercharger was prone to LSPI.It's my understanding is that Toyota is the first company to discover that oil was contributing to the problem, and they published a paper to that effect Toyota’s SAE 2013-01-2569
And API made more mess with lowering ZDDP in API SM and later.SN+ (2017) was the first API category to address LSPI, but yes, it took them ages to develop a reliable test for it.
