My 1994 350+k miles LS40 OCI: 7-8k/6mo with dino, 14-16k/12mo with syn. FCI is once a year, reuse oil filter with dino. The most expensive oil filter I use in that car is P1, other filters are OCOD, Motocraft FL400S and other various low cost filters($2-3).
I think in a clean engine there isn't much to filter, even the OCOD can hold 6-7 grams of debris. If an engine generates more than 6-7 grams of metals then it's dying, no matter how good a filter you use it will die soon. That LS400 engine is still running almost as smoothly as new, the other car parts is different story.
The filter is mounted horizontal on that engine, after 1 year of use up to 15-16k miles the filter still had much oil inside after laying upside down for several days, that means the ADBV was working okay.
Summary, you can use Motocraft oil filter for a full 15-16k miles OCI without problem !
