Anyone else turn everything off when you stop the car?
If you come into your garage with the turbos spinning at anything greater than idle, you must have a very large garage, driveway, alleyway or high speed residential street. If you're turbos aren't liquid cooled, you are driving something older than 20years. There are two twin turbo V6s in my garage. I shut them off as soon as they are put in park. As quick as a turbo spools up, it will spool down again...a few seconds at most.
My S-15 Jimmy developed a quirk towards the end of its stay with me where the wiper would occasionally make one swipe across the windshield when I started it, even though the switch was in the "off" position. I hated having to clean/loosen them without help from the defroster but I didn't want to turn the truck on and risk stripping something in the wiper linkage.
I fixed a GMT800 with the same issue. Initially thought it was the pulse board in motor but turned out to be the wiper switch. The pulse board was also bad because at first the wipers only worked on high.
I kinda suspect a bad pulse board toasts the switch or vise versa -- can't prove that, however.
As long as I can remember when I put my vehicle in park I turn all the accessories off before I shut the engine off. Thinking has always been it probably isn't the best for the AC compressor and/or the blower motor to come on hard from a dead stop. Radio too because I like to hear the start-up in case something is off. This started back when I was driving $300 junk and I just kept doing it. Don't know if it helps anything but can't hurt.
All off. A/C off 2 blocks from home.
Fan, wipers and AC off.
On a hill: I set the parking brake with car in neutral, release brake to let PB hold the car, then shift into park, 1st or R.
The radio is never on because I don’t listen to it. 🙂
Only wipers and lights because my RAV4 since it’s a base model doesn’t have automatic lights. Everything else stays set exactly the way it is and I never change it. Radio stays on and on the same channel at all times when operating and air/heat stays on. I know one guy who cuts everything off when he gets out and it drives me insane lol. I need the air blowing on me as soon as the car starts not 30 seconds after when you turn it on.
That's funny, because mine does. Some cars have turbo shaft speed sensor. Mine is displayed on a monitor.
Mine goes to 110,000 rpm under load. Responds quickly to load changes. Idle is ~5k.
To the OP, I like to pull fuses when I park just to make sure.
You don’t disconnect the ground cable as well?
Shame!
Own a bunch of old beaters, with switches for just about everything. Been shutting down all the accessories since the 70's, and never broke that habit. So, yeah. I shut most everything off before I shut down the engine. Also flip up the wipers before a snowstorm to make it easier to clear windshield.
I shut down a/c a mile from home in hopes of drying things out. Doesn't work, once it gets whatever mold in there, it's seemingly there going forward (or I've not used the good stuff to kill it).
I love the fact that my Corolla is smart enough to buzz at me if I take the key out with the headlights on... but not actually turn the lights off. ? Like, they could have easily fixed that, but no, this is how they shame you when you buy a cheap(er) car. Regardless, in general, lights, wipers, a/c off. Radio though I'll leave as-is, but I usually drive with the radio off anyhow. [But on this Corolla I got into the habit of turning the radio off as it would kill the battery. Not sure there was a fault in the radio someplace but I did have a bad battery that finally stopped holding enough charge overnight to start.]
A turbo spinning at 10,000 rpm will not spool down in a matter of seconds. Turbos are prone to wipe out the plain bearing in extreme cases where the oil stops flowing when they're spinning at high rpm.
A friend in NZ had a JDM Mitsubishi turbo diesel van. After the ignition was turned off, the engine would continue to run for another minute or two so as to continue to supply oil to the turbo while it (the turbo) was spooling down.
Jeeps - if it was raining I turn the wipers off. BMW and LR3 are auto wipers. Otherwise don't touch anything. Sometimes I'll adjust the climate control up or down so it's set right for next remote start session. If it was snowy/icy but won't be next time I drive, sometimes I'll put the Wrangler back into 2WD as I pull it in.
JDM are my initials and Mitsubishi is my game 🎮 I even turn off the engine too 😁
I shut off the AC about 5 minutes before pulling into a parking space. This dries out the ducts so that mold doesn't form.
Remember - the a/c system is a dehumidifier. Ever notice pools of water on ground after operating a/c system? This is reason a/c compressor runs when activating the defroster. Removes moisture from inside windshield
Modern cars are designed to operate (start and stop) without much driver intervention. There is absolutely NO practical reason to turn components on or off (outside possibly the wipers if doesn't have rain detection). Doing otherwise only means you don't have enough more important items to occupy the grey matter. You might seek medical help.
The only time I would consider a idle cool down is if you are finishing hot laps.
I drive a bunch of caveman vehicles with manual controls so I frequently turn stuff off. Its more for me than the car or truck. Not a fan of a blast of hot or cold air in the wrong season, a screech of the radio blasting some 80's tunes, or a smear of the wipers when there is no juice to lube/clean the windshield.
