How is the compressor turning off any different from pushing the AC button vs turning the car off?
People sure have strange OCDs.
I like to turn the AC off because the next time I start up will likely be the next morning and I don’t really need ice cold air blasting on my face when it’s cooler outside anyway.How is the compressor turning off any different from pushing the AC button vs turning the car off?
People sure have strange OCDs.![]()
The concern from OP was leaving the compressor and other items "ON" when starting the car the next time they go in to drive it.How is the compressor turning off any different from pushing the AC button vs turning the car off?
Ok, let’s reverse it then. How is turning the compressor on with the ignition any different than pushing a button?The concern from OP was leaving the compressor and other items "ON" when starting the car the next time they go in to drive it.
In a modern car, no difference at all. The computer will run through its startup sequence and engage the compressor when it is ok to do so.Ok, let’s reverse it then. How is turning the compressor on with the ignition any different than pushing a button?
That’s bit me a few times when driving other cars. I got very used to that. The EqEV does have something similar as it doesn’t have a power button but I don’t think it auto locks? Don’t remember, only driven it like a dozen times.No, I just get out and walk away. Don't shifft into whatever. No turning off anything; there is no engine, it does whatever it does. My old timer cars confuse me. Too much nonsense to remember.
Just gotta remember to take my phone. It barks at me if I don't.
Only wipers get turned off. With remote starting I want the HVAC system to come on.
With EPB in my Silverado it will set if it senses being parked on an incline automatically.
In an older car, the assumption is that the compressor engaged could make it harder to start. I'm not sure if that's true or not, or that if it really matters.
If that's true then the practice is meaningless but harmless. My concern is being gentle on the 07 Fusion. And as said I like to hear start-up without the fan blasting or radio on.It makes no difference at all because even cars from the early 90s that I had, cut accessory power when the ignition was turned to crank.
A turbo spinning at 10,000 rpm will not spool down in a matter of seconds. Turbos are prone to wipe out the plain bearing in extreme cases where the oil stops flowing when they're spinning at high rpm.No, cool down. Spool down takes a matter of seconds, cool down takes a little longer. You know, keep some oil flowing through the bearing housing for a little bit.
This is an interesting side discussion. When does a turbo spin at 10K rpms? @75 passing on the highway? @ 25 on a residential street going home? Curious because we had a 1.5T Equinox and I never heard the turbo spooling down after shutdown but maybe they don't make any noise?A turbo spinning at 10,000 rpm will not spool down in a matter of seconds.
That's funny, because mine does. Some cars have turbo shaft speed sensor. Mine is displayed on a monitor.A turbo spinning at 10,000 rpm will not spool down in a matter of seconds. Turbos are prone to wipe out the plain bearing in extreme cases where the oil stops flowing when they're spinning at high rpm.
That's true, but I'm not pulling into my garage with a turbo spinning at all, let alone full speed.A turbo spinning at 10,000 rpm will not spool down in a matter of seconds. Turbos are prone to wipe out the plain bearing in extreme cases where the oil stops flowing when they're spinning at high rpm.
My S-15 Jimmy developed a quirk towards the end of its stay with me where the wiper would occasionally make one swipe across the windshield when I started it, even though the switch was in the "off" position. I hated having to clean/loosen them without help from the defroster but I didn't want to turn the truck on and risk stripping something in the wiper linkage.Nothing annoys me more than going to start the car after sitting through a Colo winter night and the wipers are frozen to the windshield, or trying to push 8" of fresh snow.
I always shut down wipers and have to remind myself to check the switch BEFORE turning the key if I was not the last person to drive the vehicle.
Everything else doesn't really matter.
