Anyone else had a Hyundai Theta II engine replacement?
I have a 2015 Hyundai Sonata, and the original Theta II engine was one of the "bad" ones. I've never heard an engine knock so badly, it went at about 122,000 miles. I had no issue at all with my local Hyundai dealer replacing the engine on warranty in September of 2022. Almost 4 years later and 50,000 miles, the new engine hasn't used the first drop of oil. Regular high quality synthetic oil changes every 3-4,000 miles. So far so good. Anyone else gone through this? And if so what's your experience been?
Lol my SIL’s 2016 Santa Fe is getting a new one right now. Blew at 130k after religious 3k (albeit conventional) OCIs. Can only hope it goes as smooth as yours has the second time around.
We have a 2012 Sonata 2.4 that received a new long block at 135k miles? I have to check my notes. Now my son’s daily at 165k. Recently thought it was consuming oil again but found a loose oil filter that was leaking profusely. (What numb nuts did the last oil change I wonder… oh right, me) So that was quite a relief 😅
Well better than it going out the tailpipe I guess.😆
My friend has one, the original engine was replaced ~5 or 6 years ago at 98k miles, the current engine has ~95k miles. It's currently driven by his daughter; they're not car people at all, so no idea how diligent she is with the oil changes. IMO it's a ticking time bomb.
Funny thing is, I was watching one of the many car/engine based YouTube channels that I do a few weeks ago, and the host was tearing down a Theta II engine relatively close to the same year I have. He stated he thought it was actually a decently designed engine, fairly basic, and evidently it was the execution of manufacturing it and not necessarily a bad design that was causing all the trouble (I know they are blaming it on not cleaning parts properly and having small shavings in the block). Hoping to get many more miles out of this replacement. Almost due for an oil change so I'll probably run a can of intake valve cleaner trough it this weekend and change it this week. Also going to switch from the Purolator Boss to the Purolator One. I've been running the Boss for years and I'm really disappointed at some confusing information with its micron rating. Evidently it may only catch particles around 45 microns or bigger. It sounds like that may depend on the model you get, but I'm not taking the risk. The One catches 20microns, and is actually cheaper.
My theory is it's a poorly designed DI system. Fuel washes the oil away from the cylinder walls, they get scored up and it started drinking oil. No one checks it and the inevitable happens.
I have seen 3 of these come to the shop, all 3 times I pulled the extended coverage paperwork and gave to the customers to take to the dealership - they all had their motors changed. Hyundai/Kia gave them no troubles with the engine replacements.
Not checking oil is a serious problem in society today. For every 10 cars that come in - 7 or 8 are low on oil and a often nothing in the stick!
It's always been a problem, well at least since full service gas stations quit being a thing! With longer OCIs and low tension rings it has got worse.
I've mentioned this before but my niece had one fail at 150,000 miles (she was the third owner of basically a beater with minimal documentation available on maintenance history) and the dealer put a used engine in for the cost of new fluids.
I was pretty impressed thinking they want customers to come back and buy a new one some day.
Not sure of the quality/history of what they installed but it's run 10.000 miles without problems.
According the the I_Do_Cars (YT) guy, it's predominantly No. 3 that eventually self-destructs. 😭
My wife's 2013 Elantra GT with the 1.8 liter NU engine galled up the piston skirts at 14,000 miles. Yes, 14,000 miles and it was ran on Super Tech full synthetic and Mobil 1. Oil changed every 3,000 miles, or less as she was a mega short tripper at 2 miles to work and back. The mechanic said that motor did not have piston squirters that could of been a contributing issue. The also tried to use the Fram ultra oil filter against me and I said NOPE, the Magnason-Moss Warranty Act allows me to run any brand name production oil filter that is made for that car. I brought it in for BAD lifter noise in winter and the aluminum debris from the skirts galling got past the oil filter in by-pass mode on cold start and contaminated the lifters. The pan was filled with aluminum debris he said.
1. A friend's small Hyundai (Elantra?), model year c. 2015, failed after several years. Hyundai installed a new engine for him.
2. A friend's sister had the engine fail on her Hyundai (Tucson?). The dealer replaced it, and the new engine failed a week or so later. The dealer installed another replacement, and the owner traded off the vehicle.
3. Friends had problems with their 2014 Hyundai Tucson. The dealer did an oil consumption test, told them to monitor the oil level, confirmed excessive oil consumption, but would not replace the engine.
They had the oil changed at the dealer at 5,000 to 6,000 km intervals.
The engine failed at under 150,000 km. Hyundai Canada and the dealer denied them a new engine because the vehicle was slightly over the 10-year extended-warranty period.
The dealer gave them a $1000 discount on the new engine as a good-will gesture.
