Took my wife's 2009 Mazda 3.7 CX-9 to shop and got it back Wednesday. It's got 235K miles. Had techs replace:
1. Plugs and Coil Paks
2. Valve Cover Gasgets
3. PCV Valve
4. Intake Plenum Gaskets
5. Belts and Tensioner
Just got in from checking it out and there is motor oil slung all over and coating the passenger side of the engine compartment. The car was a tad over a quart low. It was topped off the day I took it to the shop. No obvious signs of leakage from the valve covers. Wherever it is coming from it is obviously being slung by the new drive belts. Anyone know if there is something they might have missed in reassembly that would lead to such an oil leak? It was not doing this prior to the service. Just got back in from checking underneath the car. The right unside is dripping or coated in fresh oil. Not ATF or Pwr Str fluid.
QUESTION: The tech called and mentioned the "stretch A/C belt" was a problem on this cars. IS THERE AN EXTERNAL OIL LINE OR SOMETHING THEY MIGHT HAVE PUNCTURED, TORN OR BROKE trying to get this "stretch belt" on????????? Oil prssure switch?
Thanks in Advance
3. PCV Valve
Thanks in Advance
