My mother has had this car since like, 2000 I want to say? When we got it from a family friend who got it new.
About 5 years ago, it got a timing belt kit done by a shop as it was above my comfort level. Tires were replaced at that point too with some generic chinese ones. They need air added to them monthly but otherwise plenty of life left.
Otherwise, for about the past 5 years, I have been handling maintenance and repairs on it. I did send her to a shop for a CV axle as I didn't want to deal with that but I've done all other stuff. Basic tune up, valve cover gasket, replaced the ABS unit with a junkyard one (no new/reman available, sad as these have a high failure rate and who knows how much longer the junkyard one will last), vehicle speed sensor speed sensor, air intake hose, etc.
AC doesn't work, it's been dead for years, but she doesn't care. There is a minor power steering leak somewhere but we have to top it up once every couple years so we ignore it. If I do decide to change the PSF I'd probably attempt to fix the leak while I'm at it because I don't like to leave things not perfect.
I've done oil changes about every 2 years because she only drives a couple thousand miles a year. She barely drives it as she usually walks or bikes to work or other places, even if it's raining!
My question is if I should go through and change all the fluids - coolant, power steering, ATF? I'm not worried about brake fluid as I did that when I did the ABS unit. Would it make sense long term? Or should I just leave it alone - am I risking messing something up? The vehicle seems to be in OK condition, although it burns a bit of oil. She has to top it up every 6 months or so. Every time I drive it I'm impressed how well it drives, honestly, I always drive her car gently compared to how I drive my stuff but this thing handles and rides GREAT! I will say it's a total stinker when cold, I don't know how long the cats have left to live, although it does pass smog every time.
