Originally Posted by HangFire
Originally Posted by danez_yoda
one of the things you cant unsee once you see it is a strobe light affect with LEDs. They simply half wave rectify the 60Hz so most of the mainline LED bulb had 60Hz flicker. It may ot mat not bother you. You can easily see it by watching your arm as you swing a karate chop while under a LED light vs incandescent. For me it is somwhat annoying.
Being sparky I am tempted to put a better rectifier and filter in the light fixtures to make the voltage nearly DC for the LEDs to eliminate the flicker.
Any good quality, modern overdriven LED takes a second or more to bring the glow down when turned off... you'll see no strobe-like effect from anything modern and decent.
I'll be honest, I thought that was just a cool effect they had put into them.
You can use a normal cell phone to check for flicker... on my iPhone 11, there's no flicker when recording at 60fps or 120fps (slo mo). But when recording at 240fps slo mo there is a flicker. Can't tell at all in person though.
