If the outside temps are in the 100s, then you will not get the inside below that without an actual cooling solution.
The cheapest and most effective relief without installing an actual AC unit, I would suggest, is a fan with water mist. You can rig something up or buy something like this.
https://a.co/d/7aypnsf
Or this, which looks better to me since it looks like you can connect it to a water tap.
https://a.co/d/grFAVgp
