Tom NJ
$100 Site Donor 2026
Originally Posted By: ADFD1
Does oil compress?
Non-Newtonian oils compress, which includes most multi-grade oils. The VI Improvers are very large molecules which will compress under pressure (temporary shear instability) and can break into smaller molecules (permanent shear instability).
This temporary loss of viscosity due to high shear rates is common in the main bearings, which is why the HTHS (High Temperature High Shear) test was developed using the temperatures and pressures found in bearings. This test looks at the remaining viscosity after the VI Improvers are compressed, and specifications are set to assure the remaining viscosity is adequate to separate metal surfaces and minimize boundary friction.
In a given set of operating conditions, there is an "ideal viscosity", that is, a lower viscosity could collapse the oil film and increase friction & wear, while higher viscosity creates drag and wastes fuel. Under normal driving conditions in a well maintained engine, the manufacturer's recommended oil grade will provide sufficient protection with respect to the oil film. In abnormal conditions, such as very hot weather, pulling heavy loads, racing, poor maintenance, cooling system malfunctions, low oil levels, engine misalignments, etc., a slightly heavier oil with a higher HTHS viscosity can provide added protection.
When it comes to recommending an oil grade, car manufacturers need to balance engine durability (warranty claims and reputation) with fuel efficiency (CAFE fines and selling point). Personally I don't trust that they always place durability high enough, so I tend to use slightly higher viscosity oils as insurance against the unexpected. That said, engine failure due to oil related wear is extremely rare, and one could argue that I am wasting a little fuel, but I view $5/yr as pretty cheap insurance.
Tom NJ
Does oil compress?
Tom NJ
