quote:
Originally posted by Blue99:
Here is a response from Mobil 1 on a mixing question, located in the FAQ archive at the M1 site:
12/09/2002 - Mixing Different Viscosities Together
Q. I have a '98 Jeep Cherokee with a 4.0-liter six-cylinder engine. I currently use Mobil 1 10W-30 in it and the oil pressure is generally good at all times including hot idle. But I have noticed that after pulling a trailer on the highway with the A/C on, the hot idle pressure is less than should be expected. My question is: The engine holds six quarts of oil and if I mix three quarts of 10W-30 and three quarts of 15W-50, will I get an oil that is a little heavier than the 10W-30? Would this make up something like a 12W-40?
-- Kevin, Pensacola FL
A. Mixing 50/50 of 10W-30 and 15W-50 will produce a viscosity in between the two. It is not possible to assign an SAE number but 15W-50 is about twice a thick as a 10W-30.
Typically, the responses from M1 in this archive are very cautious and frequently are prefaced with "Consult your owners manual".
What is apparent in this response is that they have no particular objections to mixing 2 different grades of M1 synthetic.
