My car is a 2020 Honda Accord Hybrid. I bought it brand new last year and next month (October 2021) would make it 1 year of me owning it. Car has 34,500 miles as of today.
Honda specified the car uses 0W20. I have done 2 oil changes and sent samples to Blackstone Laboratory. UOA posted here.
For the third oil change, I had some leftover oil of different weights that I almost threw away by taking to dump at AutoZone, but I changed my mind. I decided to use the oil to cycle in my engine and rinse or say wash the engine and dump.
So, I did my oil change with a mixture of; (picture below)
- 1/2 quart M1 0W20 EP High Mileage
- 1/2 M1 0W20 EP
- 1 quart M1 5W20 Annual Performance
- 3 quarts of 5W30 Shell Rotella Gas Truck.
I mixed all that and it made 5 quarts of oil.I put 4 quarts in my car. My hope was to drive it for 6,000 miles and dump it. But, I just realized this combo has dropped my MPG. I like to hypermile and now I can barely get my car to get 60mpg and above.
Here is my data since my oil change. You see I am only in the low 50s. But when I hypermile, I often get upper 50s or low 60s. Picture of my recent mpg numbers after each fill up since my oil change.
So, I have concluded that the current mixture in my car may be too thick and has caused my mpg to drop. Hence, I may dump this oil at around 2,000 or 3,000 miles of use after it has circulated well enough to "rinse" the engine.
After playing in my mind with the thought of mixing oils, I decided I wanted to try the 0W16, which is NOT specified for my 2020 Honda Accord Hybrid.
After a small research, I found out the Toyota 0W16 is made by Mobil 1 and has a good additive package. I went and bought 2 quarts from the dealership today.
I plan to do an oil change with;
- 2 quarts of Toyota 0W16
- 2 quarts of Castrol Edge HM 0W20
So, a funny thought crossed my mind that maybe 0W16+0W20=0W18?
I really plan to do this to see what will happen. I doubt it will do any harm to my car for one oil change of maybe about 7,000 miles to maybe 10,000 miles. I want to see if this will make any noticeable difference like improve gas mileage or car idles smoother or smoother acceleration. Let me just say any slight thing that my mind tricks me into thinking it is a noticeable improvement that was not there before. But I hope it still protects my car.
If the combo bothers me, I will drain and put only my required 0W20.
What are your thoughts?
- 1/2 M1 0W20 EP
