Pennzoil Platinum 5W20, Honda Civic R18, 7259 mi
Arizona
I thought that I would share the results of the last oil change on my Civic. The oil used was 3 qts of 5W-20 Pennzoil Platinum and 1 qt of 0W-20 Subaru branded Idemitsu SM that I had on hand. The Maintenance Minder was at 15% oil life remaining when changed. The previous fill was 100% Pennzoil Platinum 5W-20 for comparison. I decided to use 5W-20 as opposed to 0W-20 as I don't think that there is a significant advantage to using the later in a climate where it rarely drops below freezing and is often quite hot. It would be good if the higher Viscosity Index were the result of a better base oil, but perhaps not so good if it is the result of a higher percentage of VI Improver in the mix. This is the last oil analysis that I plan to perform on this car as the results appear acceptable to me, and I used my last Blackstone sample kit. Cheers, Jeff OIL Penplat PenPlat Toyota Honda Univ GRADE 5W20 5W20 0w20 0w20 Avg MILES IN USE 7529 5782 6033 5742 MILES 28119 20860 15078 9045 SAMPLE TAKEN 5/18/14 11/24/136/9/13 11/10/12 ALUMINUM 14 16 25 14 8 CHROMIUM 0 0 0 0 0 IRON 7 6 12 8 8 COPPER 1 2 4 5 0 LEAD 0 0 0 0 0 TIN 0 2 1 2 1 MOLYBDENUM 61 63 185 662 72 NICKEL 0 0 0 0 0 MANGANESE 1 1 1 1 1 SILVER 0 0 0 0 0 TITANIUM 0 0 0 0 2 POTASSIUM 0 0 0 5 14 BORON 27 5 10 35 43 SILICON 16 17 26 45 16 SODIUM 4 7 5 0 44 CALCIUM 2224 2237 2220 1850 2104 MAGNESIUM 12 13 20 7 175 PHOSPHORUS 564 566 767 697 669 ZINC 661 633 934 839 774 BARIUM 0 0 0 0 0 SUS VIS 210ºF 48.9 51.3 52.2 51.4 cSt @ 212ºF 6.93 7.66 7.94 7.70 FLASHPOINT ºF 420 370 410 405 FUEL <0.5 <0.5 <0.5 <0.5 ANTIFREEZE 0.0 0.0 0.0 0.0 WATER 0.0 0.0 0.0 0.0 INSOLUBLES TR 0.1 0.2 0.3 TBN 4.6 2.6 2.6 0.2 FILTER Honda Purolat Honda Honda A02 PL14610 A02 A02
SnPb
Arizona
I apologize for the lack of spacing in the table, but I couldn't resolve it before the post as locked and I could no longer edit it.
SnPb
Arizona
Code:
CHROMIUM        0       0       0       0       0
IRON            7       6       12      8       8
COPPER          1       2       4       5       0
LEAD            0       0       0       0	0
TIN             0       2       1       2       1
NICKEL          0       0       0       0       0
MANGANESE       1       1       1       1       1
SILVER          0       0       0       0       0
TITANIUM        0       0       0       0       2
BORON           27      5       10      35      43
SODIUM          4       7       5       0       44
BARIUM          0       0       0       0       0
TBN             4.6     2.6     2.6     0.2
                A02     PL14610 A02	A02
MN
The Toyota 0w-20 gave you lots more wear metals. The PP/Oil Filters lowered your Insolubles. Which Oil Filters did you use? I'd stay with PP. thumbsup
MN
Originally Posted By: Trav
You heretic. LOL
I know. crackmeup gladiator
'Stralia
Clearly the TGMO run was an issue with the engine, not the lubricant, as TGMO is the best that there is, and the only time that it doesn't looks so, there's another factor (the engine) at work... Nice series of tests, and I concur with your conclusions.
SnPb
Arizona
Turk, Honda A02 Filters were used, except a Purolator Pure1 was used with the first fill of Pennzoil Platinum.
Toronto, Canada
I don't know why people keep repeating the myth that Honda engines are "easy on oil". This R18 sheared the oil from ~8.5 cst to under 7 cst after 7.5k miles on PP which is considered a top shelf synthetic. While the TBN remained strong probably due a lot of highway trips, the oil took a hard physical beating to shear so much especially with no trace of water and minimal fuel dilution. A less stout oil like bulk dino 5w20 would've probably sheared out of grade after 5k miles and caused excessive engine wear if ran to 0% OLM.
