Another ACDelco equivalent to PH3593A (Honda size filter)
Fairfield County, CT
In addition to the PF1127, which Terry says he likes for Hondas, there's also the PF57 (p/n 25013451)
In this area, older PF57 stock looks identical in construction to the sturdy SAAB filter I dissected in this thread. I like these UK-made filters because they pack a lot of media into a smaller case, have a strong, thick center tube, and have a solid bypass valve.
Newer PF57 stock looks identical in construction to other filters made by Champion Labs, including the aforementioned PF1127, EXCEPT that the PF57 has the bypass valve mounted at the front (at the baseplate end) which some people seem to prefer (said to prevent dirt from recirculating during filter bypass). It's hard to front-bypass filters in this Honda size, but it looks like I've found one...
I think all these may interchange.
PF-1127 LF3462 L14459 PH3593A TMR-10SS 20X1.5 10SS $69.95
PF-1222 LF3537 L14460 PH6010A
PF-1230 LF3692 L14620 PH7317
PF-1177 LF798^1 L14622 PH6607
PF-1237 L10193 PH3950 OUTER
PF-2192
