And kids today cant even drive stick.......
All dum dum had to do to instantly take off into the sky was just press the eject button. He'd take off without the plane but who needs that anyway...
The start up on the F-18 doesn't seem nearly as complex at the start up in the 757 - 767.
We'll see what @Astro14 says, he's flown each of them.
There is a company in Colorado that has certification for LS/LT swaps into a few Cessna models. They've essentially made it a start and go. No magneto checks, or run up test.
The company is Corsair engines based in Colorado Springs. I think the use LS-3 engines.
No run-up? If that's true, it makes me wonder how a pilot would know that the engine is capable of take-off power?
I watched the video on their website and you don't need to do a run-up unless you are using leaded fuel, like avgas. The reason is that you can get lead built up on the spark plugs with leaded fuel, so you do a run-up to get everything good and hot, which will usually melt the lead off the spark plugs or give you a clear indication that you can't develop full power. Auto gas doesn't have lead.
https://corsairpower.com/
The Hornet is easy compared with the Tomcat.
It is also easier than the 757/767.
60 second startup and go is risky - unless the inertial is already aligned. Without a good platform, the airplane is quite compromised.
