Amsoil XL 5w30 / Auto-RX
virginia
Would this be ok to use in the clean and rinse phase?
If not, please advise what's the best dino to use.
Thankx,
bill
The only Group III 4-stroke engine oil that Amsoil makes is the XL series (5W-20 XLM, 5w30 XLF, 10w30 XLT, and 10W-40 XLO):
So with the XL exception, Amsoil doesn’t make any Group III oils:
AMSOIL has publicly stated that its XL motor oils are Group III based and its other motor oils are PAO based, specific formulary information beyond that is exclusive and proprietary.
XLM 5w30 Synthetic Motor Oil
API SM/CF, SL, SJ ...
ILSAC GF-4, 3 ...
ACEA A1/B1
JASO VTW
GM 6094M, 4718
Ford WSS-M2C929-A
Daimler Chrysler MS-6395N
Use the cheapest conventional oil you can find and you will be happy with the results! If you decide to go another route then do not waste the money on the Auto-Rx. No sense wasteing money if you do not follow the advice of the inventor then you will not get the best results or no results at all. It can technicaly be used for the clean phase but you will not get as good of results as if you used dino. The rinse phase must repeat must be cheap dino the soften junk will not let lose from the medal it will stay exactly where it is at in the engine.
