This is my brother's tundra, which is used mostly for towing in excess of 8k lbs most of the time. His truck did have more miles than mine by 800 or so, and he drives more around town than i do.
He put 9082 miles on the oil in 11 months, and he also replaced the oem filter twice during this OCI.
OAI in SLC, Utah did the report.
Data flagged for observation only; TBN is moderately low; oil is suitable for continued use. Re-sample in 3500 miles or 65 hours.
*********Wear metals ppm*
IRON--17
CHROMIUM--0
NICKEL--0
ALUMINUM--8
COPPER--5
LEAD--0
TIN--0
CADMIUM--0
SILVER--0
TITANIUM--0
VANADIUM--0
*********Contaminant metals--ppm**
SILICON--16------TRD air filter.
SODIUM--10
POTASSIUM--2---What?
*********Multi source metals ppm**
MOLYBDENUM--9
ANTIMONY--0
MANGANESE--0
LITHIUM--0
BORON--13---SSO have boron in it?
********Additive metals ppm*
MAGNESIUM--13
CALCIUM--3786
BARIUM--0
PHOSPHOROUS--570
ZINC--675
DATE sampled--7/28/10
Date received--8/02/10
Unit time--11 months
Lube time--9082 miles
Lube change--yes
Filter change--yes
FUEL--less than .1%
SOOT--less than .1%
WATER--less than .1%
VIS @ 100.C--10.1--Close to virgin which is 10.3
TAN---not listed
TBN--3.31
I-R OXIDA--41---A little high?
I-R NITRA--24
Total miles on his truck are 31k.
I am not so dissapointed in the UOA after using this high end oil. However, the truck is a little noisy on the lower visc. oils for some reason. I just replaced this oil and filter using HDD 5w30 and TRD filter, even though toyota recomends a 0w20 or 5w/20 for this motor. We'll see how this run of the HDD goes next year. So far, it's much quieter. The 5.7 seems to like this oil already; at idle it is extremely quieter. It's even made the magnaflow exhaust louder for some reason.
Please comment.........
Thanks
EDIT BY MOD: Here is a UOA from my truck for comparison.
IRON--17
CHROMIUM--0
NICKEL--0
ALUMINUM--8
COPPER--5
LEAD--0
TIN--0
CADMIUM--0
SILVER--0
TITANIUM--0
VANADIUM--0
SODIUM--10
MOLYBDENUM--9
ANTIMONY--0
MANGANESE--0
LITHIUM--0
MAGNESIUM--13
CALCIUM--3786
BARIUM--0
PHOSPHOROUS--570
ZINC--675
Lube change--yes
Filter change--yes
FUEL--less than .1%
SOOT--less than .1%
TAN---not listed
TBN--3.31
I-R NITRA--24
Thanks
