Amsoil Sig 10w30, 10K, 07 Chevy 3500
Texas
Around the 5-6K mile marker the owner had a rear main seal leak in the engine and had the gaskets replaced. I believe that is mostly responsible for the large spike in Silicon, although the high wear numbers also indicate that dirt could have been dumped in the engine during this work.
Make/Model: GM 8.1L V8
Vehicle: 2007 Chevrolet 3500
Oil: Amsoil Signature Series 10w-30
Filter: Amsoil EA
Code:
OIL Amsoil 10w30 Amsoil 10w30 Valvoline 10w30
MILES IN USE 10,389 6,000 3,000
MILES ON UNIT 140K 130K 123K
SAMPLE TAKEN 4/17/13 10/23/12 9/5/12
MAKE UP OIL 5 QT 2 QT 1 QT
IRON 124 34 10
CHROMIUM 3 1 0
NICKEL 2 1 0
ALUMINUM 33 10 3
COPPER 3 1 0
LEAD 11 14 8
TIN 1 0 0
cADMIUM 0 0 0
SILVER 0 0 0
VANADIUM 0 0 0
SILICON 69 27 12
SODIUM 96 78 177
POTASSIUM 9 4 0
TITANIUM 0 0 0
MOLYBDENUM 150 144 31
ANTIMONY 0 1 0
MANGANESE 33 30 47
LITHIUM 0 0 0
BORON 70 67 0
MAGNESIUM 23 19 17
CALCIUM 3495 3556 2298
BARIUM 0 0 0
PHOSPHORUS 769 727 773
ZINC 861 848 861
Fuel %
soot %
Water %
Visc @ 100C 11.2 11.0 8.9
Base Number 3.40 5.54 4.55
Oxidation 52 48 10
Nitration 15 11 8
Yeah, hard to judge a UOA based on that much make up oil... Seems like you are using some oil in this truck. Maybe time to look at a HM oil???
Those numbers make no sense.
Now if we go back to the valvoline sample and iron shows 10,but the amsoil at roughly double the mileage has over triple the iron on sample 2 then sample 3 goes thru the roof.
And there is that much iron in a sample that was diluted with 5 extra quarts of oil.
There has gotta be something either wrong with the sample or something really wrong with the engine itself.
Go back to conventional and try and establish some kind of baseline then decide from there if using a syn is cost effective. By the looks of it your engine is dissolving
You might want to check for a vacuum leak in the intake manifold, air filter housing, hoses, and etc... as the silicon levels are high and iron is way up.
After a major engine service (seals/gaskeets replaced) where work was done and dirt likely got in, there is no ability to really see anything clearly.
Do a couple of OCI flushes at whatever interval they choose, and then sample again. Get the noise out before you make any conclusions.
Exactly.
