For those using Amsoil, there are a number of overtsized oil filters that can be used. Amsoil equips all their filters with both an antidrainback valve; most also have an internal by-pass valve. In many cases the oversized filter is simply a longer version of the stock item. These are some common filter substitutions I've used:
Stock Filter/Substitute Oversized Filters
SDF-57/SDF-34/SDF-96 (toyota/Saturn)
SDF-34/SDF-96/SDF-15 (many early VW/Audi engines)
SDF-29/SDF-23 (many GM V-6 engines)
SDF-20/SDF-36 (many Honda/Isuzu engines)
SDF-96/SDF-15 (early model Toyota/Datsun engines)
SDF-15/SDF-26 (many Ford V-6/V-8 engines)
SDF-25/SDF-24 (many GM V-8's)
SDF-41/SDF-99 (early Ford Powerstroke diesels)
SDF-13/SDF-20 (many Nissan/Mitsu/Mazda engines)
When making any filter substitution, you should always make sure their is sufficient clearance to remove the filter and that it doesn't hit anything as the engine moves on its' mounts. You should also make sure the filter doesn't hang significantly below the engine, where it may be impacted by road debrie.
If you need dimensions on any of these filters, please let me know ....
Tooslick
Tooslick
