Thanks Patman!quote:
Originally posted by Patman:
It's true, the 20195 is the long version of that filter. They both share the same bypass setting of 12-15psi, both flow 3gpm and both have an antidrainback valve. Same connection size too (3/4-16" UNF-2B) Here are their dimensions:quote:
Originally posted by Scott in WI:
Hey Patman,
As long as you're getting out your Purolator catalog, can you confirm for me that the PL20195 is the "long version" of the PL10241? Also, can you post the important information (dia, length, bpv setting, gasket dia, etc.) for both of them?
Thanks!![]()
L10241 is 2.98 x 3.42
L20195 is 2.98 x 4.77
And as was confirmed above the L30001 does have an antidrainback valve.
