Filter options for building your own bypass system
Florida Ma.
I've had some filter heads lying around for quite some time and decided that it's time to find what filter options there are that fit them for use on my vehicles & equipment.
Thought others could benefit from my efforts so here is my list. There may be some errors in cross referencing so verify before you buy.
The list is sorted by filter base thread size; ¾, 1-12, 1-16, 1-3/8 base sizes.
My information is from Fleetguard & Wix.
I have two Amsoil dual bypass filter heads which have ¾-16 threads on the full flow side and 1-16 on the bypass side, one 1-12 filter head and one dual filter bypass head that is 1-3/8-16.
Dodge Cummins oil filters are 1-16. Wix filter # 57136 is a 10 micron full flow filter made for Dodge Cummins remote mount applications. Wix # 57620XE is a high efficiency paper glass filter rated at 14 microns.
Wix also makes a glass media filter (¾-16) # 57515 rated at 12 microns which is a HD version of their 20 micron 51515.
The filters that I included the Wix# and micron & flow rates on are those I’m considering for use.
The list includes fuel, lube, hydraulic and bypass filters.
Thanks Tim
Fleetguard# 3/4-16 base
FF = Fuel Wix # Micron/GPM
FF5172 4.18 (106) 3.13 33393 10/8-10
FF5039 7.31 (186) 4.25 33281 10/7-9
FF5094 7.14 (181) 4.26 33281
FF5368 6.89 (175) 3.31 0
FF5096 6.05 (154) 3.69 0
FF5058 5.91 (150) 3.05 12
FF5307 5.75 (146) 3.86 7
FF226 5.59 (142) 3.68 33281 10/7-9
FF5266 5.48 (139) 3.69 33343 10
FF5116 5.36 (136) 3.13 33393 10/8-10
FF5412 5.14 (131) 3.70 0
FF5141 5.01 (127) 3.72 33343
FF5108 4.82 (123) 3.82 33398 19/7-9
FF4136 4.63 (118) 3.05 33398
FF5304 4.58 (116) 3.06 12
FF5043 4.51 (115) 4.25 0
FF5158 4.49 (114) 3.32 33393
FF5163 4.40 (112) 3.05 33476 10
FF5138 3.98 (101) 3.32 33393
FF5030 3.49 (89) 3.05 33393
FF5081 3.50 (89) 3.05 33393
FF5451 3.22 (82) 3.31 33386 10/7-9
FF5114 3.22 (82) 3.31 33386
FF5092 3.08 (78) 3.05 0
FF5231 3.62 (92) 3.68 33386
FF5432 4.86 (124) 2.84 33138 7
FF5159 0.00 (0) 3.70 33138
HF = Hydraulic
HF6158 3.45 (88) 3.04 21
HF6107 5.98 (152) 3.68 28
HF6351 5.61 (143) 3.68 21
HF28859 5.61 (143) 3.68 0
HF6315 5.61 (143) 3.68 0
HF35341 5.59 (142) 3.68 0
HF6352 4.59 (117) 3.68 19
HF35254 4.02 (102) 3.36 57088 10/7-9
HF35308 4.02 (102) 3.31 21
HF28945 3.92 (100) 3.15 0
HF6096 3.85 (98) 3.70 21
HF6164 3.85 (98) 3.72 21
HF6446 3.84 (98) 3.69 57102 10/7-9
HF35099 3.49 (89) 3.05 51369 10/ 7-9
HF28783 3.50 (89) 3.05 28
HF35077 5.51 (140) 3.15 18
LF = Lube filter
LF3568 4.75 (121) 2.96 51342 21
LF3599 4.74 (120) 3.00 0
LF3615 3.46 (88) 2.69 0
LF3604 3.20 (81) 3.61 51085 21
LF3614 2.90 (74) 2.67 51394 21
LF3483 8.98 (228) 4.25 0
LF3583 7.33 (186) 4.25 51431 29
LF3347 7.31 (186) 4.25 32
LF3580 7.10 (180) 3.68 0
LF3947 6.95 (177) 3.68 0
LF697 6.90 (175) 3.78 32
LF787 6.86 (174) 3.80 32
LF3652 6.66 (169) 4.27 51641 12/7-9
LF3334 6.43 (163) 3.31 21
LF781 5.91 (150) 3.05 21
LF3314 5.76 (146) 3.78 21
LF682 5.69 (145) 4.24 23
LF3481 5.71 (145) 4.25 29
LF3489 5.71 (145) 4.25 0 0
LF3530 5.69 (145) 3.78 21
LF3324 5.69 (145) 3.78 21
LF3792 5.59 (142) 3.68 0 0
LF3449 5.59 (142) 3.68 25
LF3451 5.59 (142) 3.68 21
LF3466 5.59 (142) 3.68 21
LF3401 5.59 (142) 3.68 0 0
LF3402 5.59 (142) 3.68 21
LF3505 5.40 (137) 3.81 21
LF3487 5.40 (137) 3.78 57515 12/7-9
LF3728 5.40 (137) 3.78 0 0
LF3685 5.40 (137) 3.78 0 0
LF551A 5.40 (137) 3.78 21
LF16208 5.35 (136) 3.66 21
LF3912 5.00 (127) 3.72 0 0
LF3638 5.01 (127) 3.72 21
LF16221 4.88 (124) 2.91 21
LF16212 4.88 (124) 2.91 21
LF4016 4.57 (116) 3.68 21
LF3659 4.57 (116) 3.68 21
LF3353 4.57 (116) 3.68 21
LF3339 4.58 (116) 3.06 21
LF3568 4.75 (121) 2.96 21
LF3615 3.46 (88) 2.69 21
LF3604 3.20 (81) 3.61 21
LF3614 2.90 (74) 2.67 21
LF3583 7.33 (186) 4.25 29
LF3466 5.59 (142) 3.68 51545 21/7-9
LF3402 5.59 (142) 3.68 51191 21/7-9
LF3505 5.40 (137) 3.81 51452 21/7-9
LF551A 5.40 (137) 3.78 51515 21
LF16208 5.35 (136) 3.66 51515
LF3638 5.01 (127) 3.72 51647 21/7-9
LF16221 4.88 (124) 2.91 51512 21/7-9
LF16212 4.88 (124) 2.91 51516 21/7-9
LF4016 4.57 (116) 3.68 51521 21/7-9
LF3659 4.57 (116) 3.68 51521 21/7-9
LF3353 4.57 (116) 3.68 51452 21/7-9
LF3339 4.58 (116) 3.06 51516 21/7-9
LF3549 4.58 (116) 3.05 51762 21/7-9
LF3555 4.57 (116) 3.05 0 21/7-9
LF655 4.57 (116) 3.05 51764 21/7-9
LF3770 4.51 (115) 4.25 51452 21/7-9
LF3499 4.48 (114) 3.28 21/7-9
LF3490 4.48 (114) 3.28 21
LF16165 4.40 (112) 2.69 32
LF3341 4.27 (108) 3.74 21
LF580 4.22 (107) 4.24 25
LF689 4.22 (107) 3.80 21
LF3501 4.22 (107) 3.80 21
LF3330 4.22 (107) 3.79 21
LF742 4.16 (106) 3.70 21
LF16222 4.17 (106) 2.91 21
LF16210 4.13 (105) 3.66 21
LF3434 4.02 (102) 3.31 21
LF3708 3.99 (101) 3.31 21
LF16218 3.94 (100) 2.91 21
LF16219 3.94 (100) 2.91 21
LF3933 3.89 (99) 3.70 21
LF16215 3.86 (98) 3.66 21
LF3795 3.79 (96) 3.81 21
LF764 3.75 (95) 3.81 21
LF3311 3.75 (95) 3.79 21
LF3400 3.62 (92) 3.68 21
LF3376 3.62 (92) 3.68 21
LF3377 3.62 (92) 3.68 21
LF3378 3.62 (92) 3.68 21
LF16011 3.52 (89) 3.05 28
LF3310 3.49 (89) 3.05 21
LF3335 3.49 (89) 3.05 21
LF3745 3.49 (89) 3.05 22
LF3766 3.48 (88) 3.06 40
LF3338 3.48 (88) 3.05 21
LF3706 3.40 (86) 3.68 21
LF3682 3.40 (86) 3.68 21
LF4014 3.39 (86) 3.07 21
LF3960 3.40 (86) 2.92 21
LF3758 3.23 (82) 3.68 21
LF3495 3.22 (82) 3.31 21
LF16028 3.21 (82) 3.05 0
LF3509 3.19 (81) 3.31 21
LF3690 2.98 (76) 3.31 21
LF3848 2.50 (64) 3.07 0
LF3778 2.34 (60) 3.78 21
Fuel Base 1-12
FF5013 7.70 (196) 3.73 0
FF5011 7.70 (196) 3.73 24348 10/ 12-16
FF216 6.91 (176) 3.69 24347 10/ 12-15
FF5034 6.86 (174) 3.69 33123 12 15
FF5641 5.61 (143) 3.72 33823 9/12-15
FF5642 5.61 (143) 3.72 33821 2/12-15
FF5012 5.42 (138) 3.69 24006 10 15
FF235 4.16 (106) 3.70 33125 10 12
Lube Base 1-12
LF3393 9.09 (231) 4.26 16/12-16
LF3790 8.96 (228) 4.23 0
LF4104 8.78 (223) 3.73 28
LF3740 8.75 (222) 3.73 28
LF3625 8.52 (216) 3.68 25
LF3744 8.31 (211) 3.68 23
LF3687 8.31 (211) 3.68 0
LF3413 8.31 (211) 3.68 25
LF4054 8.27 (210) 3.68 25
LF3455 8.11 (206) 4.26 51747 16/12-16
LF3421 8.10 (206) 3.69 24
LF3420 8.06 (205) 3.78 24
LF3560 8.06 (205) 3.78 0
LF673 7.99 (203) 3.72 32
LF3932 7.96 (202) 3.68 25
LF797 7.91 (201) 3.72 25
LF3864 7.31 (186) 4.25 0
LF702 7.14 (181) 4.26 32
LF3919 6.95 (177) 3.68 0
LF694 6.91 (176) 3.69 25
LF3316 6.88 (175) 3.78 24
LF3559 6.88 (175) 3.78 0
LF3382 6.88 (175) 3.78 35
LF708 6.88 (175) 3.78 32
LF690 6.90 (175) 3.78 32
LF3861 6.90 (175) 3.71 32
LF4017 6.85 (174) 3.68 32
LF4154 6.85 (174) 3.68 32
LF3331 6.85 (174) 3.68 25
LF3307 6.82 (173) 3.81 17/12-16
LF3665 5.93 (151) 4.19 23
LF3650 5.77 (147) 3.72 0
LF3642 5.73 (146) 4.33 32
LF3443SC 5.77 (146) 4.24 0
LF3808 5.69 (145) 4.33 0
LF3752 5.70 (145) 4.24 23
LF4056 5.59 (142) 3.68 23
LF654 5.42 (138) 3.69 23
LF3788 5.42 (138) 3.69 35
LF3464 5.34 (136) 4.25 35
LF3497 5.22 (133) 4.26 32
LF760 5.22 (133) 3.72 51609 15/12-16
LF3653 4.57 (116) 3.68 35
LF3532 4.28 (109) 3.73 35
LF3828 4.04 (103) 4.33 32
LF3417 3.85 (98) 3.72 35
LF3415 3.41 (87) 3.72 51609 15
LF3508 5.18 (132) 4.52 51091 21
LF3666 6.89 (175) 4.19 51725 23
Cummins Mount 1-16
LF3398 7.22 (183) 4.24 32
LF3972 6.96 (177) 3.68 57620 20/12-15
LF3934 6.94 (176) 3.69 0
LF3806 6.94 (176) 3.69 17
LF3713 6.94 (176) 3.69 17
LF9028 6.94 (176) 3.69 57620XE 14
LF16006 6.94 (176) 3.68 57136 10
LF3552 6.94 (176) 3.69 57620XE 14
LF16035 6.94 (176) 3.68 57620XE 14
LF3959 6.94 (176) 3.68 17
LF3894 6.93 (176) 3.68 51607 17
LF3921 6.90 (175) 3.69 17
LF3915 5.81 (148) 3.69 30
LF16007 5.82 (148) 3.69 30
LF739 5.74 (146) 4.24 25
LF3805 5.44 (138) 3.69 17
LF3553 5.44 (138) 3.69 0
LF3922 5.40 (137) 3.69 17
Large Dual Bypass 1-3/8-16
LF3410 11.31 (287) 4.74 51749 5/1.75
LF3635 11.31 (287) 4.74 51749 5/1.75
LF3542 9.81 (249) 4.74 51749 5/1.75
LF3544 9.81 (249) 4.74 51728 9/24-28
LF3654 10.39 (264) 4.24 51660 10/Bypass
LF3603 9.78 (248) 4.66 51728 9
Fuel
FF5132 12.19 (310) 5.41 33385 6/24-28
FF5317 12.17 (309) 5.41 33685 6/24-28
When posted the spacing needed to understand the list was eliminated so here is the meaning of the number groups.
The first number starting with FF, LF, HF are Fleetguard numbers.
The 2nd 3rd & 4th set of numbers are length & diameter of filter.
The 5th number set is the Wix PN
The 6th number set if shown for example 10/8-10 means 10 micron 8 to 10gpm flow.
Tim
Originally Posted By: Colt45ws
If you put the data in a
Code:
Code box
it will keep your formatting.
Don't know how to do that.
here it is in code, press the '#' symbol, select 'code'
just a copy paste, so dont know if your formatting is still present.
Code:
HF = Hydraulic
LF = Lube filter
Fuel Base 1-12
Lube Base 1-12
Cummins Mount 1-16
Fuel
