amsoil ATM 10w30, 15k miles, w/ TAN
pb
stl
http://tinyurl.com/omsjljw
severity 2: Flagged data does not indicate an immediate need for maintenance action. Continue to observe the trend and monitor equipment and fluid conditions. Base number is moderately low. As base number depletes, the ability to neutralize acids is diminished and corrosive wear may occur. Sludge and deposits may form. Silicon is at a minor level; silicon sources can be abrasives, seals and gasket material, lube additive or lube supplement, and/ or environmental contaminant; viscosity is slightly high. Causes include contamination, oxidation, incorrectly identified viscosity grade, or adding a different viscosity grade to the component. Boron is slightly low for this lubricant.
Code:
OIL ATM 10W30 ATM 10W30 ATM 10W30 ATM 10W30 ATM 10W30 ATM 10W30 ATM 10W30 ATM 10W30 ATM 10W30 ATM 10W30 ATM 10W30 ATM 10W30 ATM 10W30 ASL 5W30 HDD 5W30 HDD 5W30 HDD 5W30 TSO 0W30 TSO 0W30 TSO 0W30 HDD 5W30 TSO 0W30 FF
MILES(TIME IN USE) 15K 10.3K 11.5K 9K 17.1k 9.9K 8K 3.4K 14.6K 12.9K 3.8K 11.8K 6K 8.4K 14.9K 13.4K 2.6K 11.3K 27.5K 18.9K 13.9K 9688 1716
O&F CHANGED Y N Y Y Y Y Y N Y N N Y N Y N Y N Y Y N Y Y Y
MILES 231.5K 227K 207K 195K 186K 169K 159K 154K 151K 149K 140K 136K 131K 125K 109K 94K 83K 81K 69K 61K 41.8K 27.1K 1716
MAKEUP OIL 1 0 0 0 1 0 0 0 0 0 0 0 0 1 0 0 0 1 1 0 2 0
SAMPLE TAKEN 16-DEC-15 7-JUL-15 28-MAY-13 31-JUL-12 21-DEC-11 18-AUG-10 17-FEB-10 31-AUG-09 30-APR-09 25-FEB-07 9-NOV-06 8-OCT-06 28-FEB-06 19-NOV-05 2-SEP-03 21-DEC-02 30-JUL-02 18-JUL-02 22-MAR-02 31-JAN-02 6-JUL-01 11-SEP-00 19-NOV-99
LAB OAI OAI OAI OAI OAI OAI OAI OAI OAI OAI OAI OAI OAI OAI OAI OAI OAI OAI OAI OAI OAI OAI OAI
IRON 25 17 21 13 24 18 14 8 21 15 5 19 13 41 62 111 16 49 91 63 48 45 36
CHROMIUM 1 0 0 0 0 0 0 0 0 0 0 0 0 0 2 2 0 0 2 1 1 1 0
NICKEL 1 0 1 1 1 0 1 0 1 0 0 0 0 0 0 0 0 1 3 2 1 2 1
ALUMINUM 4 4 3 1 7 3 3 1 3 2 2 7 3 8 10 14 9 10 6 12 9 12 9
COPPER 13 9 8 4 10 7 6 12 8 10 4 15 8 17 42 55 9 22 4 20 14 24 131
LEAD 3 2 1 1 5 3 2 1 5 9 0 5 1 6 17 21 3 8 7 7 8 6 9
TIN 0 0 0 0 0 0 1 0 1 0 0 0 0 0 0 0 1 2 2 3 2 1 1
CADMIUM 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
SILVER 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
VANADIUM 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
SILICON 22 20 34 23 37 43 32 18 13 18 11 24 21 20 40 27 9 27 37 37 50 54 139
SODIUM 7 7 8 7 11 8 7 5 10 9 0 11 0 0 14 13 2 3 6 5 5 5 10
POTASSIUM 4 1 2 0 0 0 1 1 1 0 0 0 0 0 0 0
TITANIUM 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
MOLYBDENUM 175 176 151 151 60 54 53 51 48 51 50 3 1 3 7 7 0 5 10 7 5 8 0
ANTIMONY 1 0 1 0 0 0 0 0 0
MANGANESE 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 4
LITHIUM 0 0 0 0 0 0 0 0 1
BORON 61 61 55 79 61 101 152 221 89 117 215 29 57 43 1 1 32 34 39 36 21 45 104
MAGNESIUM 18 18 18 16 16 16 26 24 84 115 103 923 908 783 43 108 34 395 351 338 46 353 69
CALCIUM 4104 4109 3580 3686 3534 3203 3349 3414 3098 3360 3246 2717 2652 2716 3930 4249 4333 3132 3147 3181 4345 3181 2237
BARIUM 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 5 0 0 0 0 0 0 5
PHOSPHOROUS 703 736 657 599 653 645 640 697 614 694 615 894 1093 1051 1165 1073 1216 1242 1239 1293 1267 1243 1160
ZINC 892 867 777 687 817 782 755 853 790 958 936 1255 1391 1283 1279 1299 1355 1569 1541 1515 1348 1536 1392
WATER 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
cSt @ 212ºF 12.5 11.9 11.7 11.3 13.1 11.6 11.5 10.9 15.2 13.06 11.65 15.95 13.79 13.55 16.13 15.27 11.5 16.7 16 13.5 15.9 11.5 9.5
FUEL 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1.2
TAN 4.08 3.34 N/R N/R N/R N/R N/R N/R N/R N/R N/R N/R N/R N/R N/R N/R N/R N/R N/R N/R N/R N/R N/R
TBN 3.09 3.27 3.34 3.42 2.79 4.02 4.29 4.91 3.88 4.78 9.92 4.54 6.75 7.01 4 9.4 12.8 6 7.9 8.4 8.7 8.1 5.7
OXIDATION 59 57 56 56 57 57 44 41 15 32 25 30 24 16 14 23 23.3 14.4 27.8 20 33.3 10 12.2
NITRATION 15 14 16 16 33 26 24 21 17 24 20 27 17 19 9 14 14.3 31.4 50 40 35.7 22.9 11.4
