Amsoil in 2005 Camry SE?
Arizona
I am thinking about putting Amsoil in my g/f's 05 Camry SE with a 3.3 V-6. I have heard that Toyota Ok'd 5w-20 in the V-6 engine. Any experience with this engine and amsoil would be greatly appreciated!
Not with that engine, but i use Amsoil ASM 0w20 in my Mazda6s V-6, which also specs 5w20. I'm going to do a 1 year OCI, also using an Amsoil oil filter. Time will tell.
The 5w-20 and 0w-20 for Toyota's START with 2006 model year.
No 2005s have been spec'd with the TSB.
Here it is.
So with that, I'd recommend 5w30 and change it every 5k or 6 months unless you have more than 60k on the engine, then do what you'd like!
Take care, bill
Amsoil S3K 5W30 would be what I would choose. I doubt you will be able to get 12 months out of any oil in AZ though due to dust. Your air filter will not catch it all and it will ruin the oil! The only way I would consider a 12 month oil change in your area would be with bypass filtration. This will get the dust out of the oil and would allow you to make the 12 month mark propably easily.
I have the same engine in my wife's 2005 Highlander. You could use 10w30 Pennzoil Platinum (PP) and be okay for 7,500 miles. Pennzoil Platinum 5w30 would be okay, too, as would Schaeffer's newer 5w30 Full Synthetic (I'm running it in the Toyo right now) or the Amsoil 5w30 that Pablo has recommended.
If it's out of warranty (4/60k?), you could try Mobil 1 0w20 or Amsoil's 0w20, but you're better off sticking with the 5w or 10w30 oils.
Amsoil is great oil when used it in the manner it is intended for: very long drains. Run it at least 10k miles, and do a used oil analysis to determine whether it would be suitable for even longer on future runs. Many people here have run Amsoil products 15k-25k and even longer with good results. If you don't intend to do that then in my humble opinion you will get much better value for your money from an off-the-shelf synthetic like Pennzoil Platinum (up to 10k-12k), a regular PCMO (5k-7500) or something like Valvoline's Maxlife Blend.
This is assuming your engine is NOT one subject to problems with sludge formation.
Here it is.
Take care, bill
I am still confused by this TSB. What changed between the 05 and 06 corolla so that the 06 is spec'd for 5W-20?
The 2006 had a shorter dipstick which allowed more oil in the crank case.
Thats all we DO know. I doubt that they changed the mfg of the engine since they are made many months before going into the bodies.
With that, I have only used 5w30 in my 2005 Corolla and will stay with it. My used oil analysis have been excellent and the MPG is great.
I'm trying a new oil and with 4k miles on it so far I've used 24 oz of makeup oil and its a 5w30. I wonder how much 5w-20 it would have been?
Take care, Bill
My 99 isn't Toyota. I bought it used with 155,000 miles, P/O used 10w30. Since this model is back-speced for 5w20, that's what I changed to and now on cool mornings there is unusual engine noise during warm-up so you should observe the note at the bottom of the tsb when choosing oil grade.
..and you don't experience this unusual noise as a heavier oil transitions through the exact same viscosity
