Amsoil guy...Switchin to M1 or PU.
I really think that an oil like Pennzoil Ultra will keep your engine cleaner in the long run versus Amsoil, and it will run better and give you a better bang for the buck.
There are just better oil's on the market that are cheaper than Amsoil and they either will give you the same results, or as in the case of PU you will be happier in the long run. JMO
I think it's funny how some just say 'any' synthetic will make it to 10K in the OP's application. For all we know, it barely makes it there on Amsoil. Now you want to use another synthetic oil in extended service, like PP or PU, and just continuously run it to 10K without question? Pretty irresponsible, IMO.
Any change in oil would demand a UOA to make sure any alternative works up to 10K mile intervals. The OP hasn't lost oil during intervals and hasn't had problems using Amsoil to 10K. Who is to say its barely making it with 1-2K miles of breathing room and another oil that IS NOT formulated for extended service would start causing problems by running it out the same way OP did using Amsoil? Which is the entire point of whether it's "cost effective" or not.
More information is needed. Short trips? Highway or city miles? Climate? Driving style? etc, etc...etc.
I'd be interested to hear why you think that Ultra will keep the engine clearner and that it will run better than Amsoil.
I'm wondering why the late change myself. I guessing with the miles I'm guessing it been paid for, so I don't understand what a few bucks is going to do. Why mess with a good thing?
Kinda the same reason why my wife's car switched back to M1 after a few changes of different oil. While nearly any oil in her car would do-the M1 get such a good job that it is worth the few extra bucks.
Much of the change depends on the driving style too...
+1 I wanna see some facts about this claim. Sounds like water cooler talk to me.
Any synthetic oil changed at reasonable OCIs will keep an engine spotless. I don't buy into the marketing [censored].
Any excellent quality Dino like PYB, Mobil Clean 5000, Castrol GTX, Valvoline White Bottle will also keep your engine spotless with proper OCI's.
Except for the Amsoil XL Line, Amsoil's other oil's are extended drain oil's.
Amsoil 100% Synthetic Oil is probably a great oil under the right conditions. Lets say you buy a brand new car, and you are only going to keep it for 5 years or 100,000 miles, and then you will be trading it in. In this scenario, Amsoil is a fine oil. The other scenario is if you are doing alot of long trip driving, say about 50 to 100 miles a day, go ahead and do an extended drain and more than likely everything will be fine.
If you are doing short trip driving, then I see that Amsoil would not be the best choice.
If you are keeping your car for maybe 200,000 or maybe even 300,000 miles, I would think that an oil like Pennzoil Ultra that has alot of cleaning properties would be the better choice.
Your engine will get dirty over many miles and years, my gut feeling is that the Amsoil 100% Synthetic probably has more anti-wear additives than it does cleaning additives.
Is Amsoil going to meet the new GF-5 Standard, seems like the new standard is going towards more cleanliness. We all know that engines do get dirty, just take a look at the threads in the Oil Additive Section.
In the short run, have fun with Amsoil, but if you are keeping your car for the long haul then you might want to look at Pennzoil Ultra.
One last thought, it is easier to keep an engine clean as opposed to trying to clean it up.
First, I disagree with you about the Amsoil XL, it is by definition an extended drain oil. It supposed to protect for up to 10,000 and could probably go further. That's extended drain.
Second, Amsoil does have a non-extended drain oil, but it is called the Amsoil OE line.
So according to your post, Ultra has LESS anti-wear additives but is LOADED with cleaning agents.
So at the end of the day, your engine will be EXTREMELY clean but completely worn out.
Sounds like B.S. to me, to be honest with you.
The way i see it, Amsoil has the same amount of cleaning agents as Ultra but is also loaded with additives that help it run much longer, hence why it costs more.
I do agree that some oils are loaded with more cleaning additives then other but at proper OCIs any El Cheapo dino oil will keep your engine spotless.
Why would a new engine require many cleaning agents? Any top rated syn oil should keep that engine clean for years to come. IMHO I'd like a syn oil that has the best anti- wear characteristics for the long haul.
I don't get on here much anymore because of threads like this , it really gets old .
You have a bunch of brand loyals trying to sell their choice , armchair warriors who try to convince you this brand or that brand because it is better for reasons only they seem to know .
Honestly friend , if your going 10K on oil changes than you're not taking advantage of the extended OCI's to keep the cost down using Amsoil . If you want to do 10K OCI's and save money than simply use any current popular synth oil out there that is on sale . In the long run it will make absolutely no difference on the outcome of the life of your engine .
There now , wasn't that easy...you'll be able to sleep good tonight .
Now.....hat oil filter should you use ?!!!
I'm sorry but there isn't anything here other than your opinion based on, well, your opinion.
Amsoil is a great product-if you need its capabilities.
A 5 qt bottle of QSUD is 19 bucks at Wallys-and will go just as long as Syntec PU PP VML M1 etc.
Save your money for something worthwhile Acura(honda) engines run forever on anything you give them as long as its changed regularly
Steve
Steve
That kinda goes for everything though, doesn't it?
I don't see what the big deal is if someone wants to use an expensive oil (or product) on his/her car. Its their money. Let them spend it on whatever they want. I hate these oil brand related recommendations.
Steve
Exactly. A few buck here or there is not a big deal.
In honesty, none of my cars really need amsoil-but I still want to try it anyways...
I agree mostly here with you Artem...but really if any oil PREVENTS your engine from getting dirty "WHY"?!, do people obsess with needing an oil that focuses on cleaning up the engine?
I personally don't use Amsoil for cleanup intervals, that is a waste, it's best used(IMO) in extended drain service.
I use other oils, like one of Pennzoil, or an HDEO, with perhaps an oil additive that is reputable for less than 5K(which in severe service is all a conventional is GREAT for, let along capable of perhaps give or take 1-2K more)...yet with a full synthetic like PP or PU in servere service in a dirty engine needing cleaning, they shouldn't be kept in for 10,000 miles at a time if needed for cleanup. Regardless of how clean it can help the 'dirty' engine become, if can't keep the gunk in suspension for extended service you are back to where you started.
I don't believe the OP has issues with needing cleaning, and if so, could benefit from another oil. In the best scenario, any synthetic could make it 10,000 miles without problems arising. The question is, what does the OP want the oil to do time wise? If he has settled on 10K, he could try another oil and work up to 10,000 but I'd do a shorter interval(5-7.5K) on my first interval with the whatever other oil the OP wants to try instead of Amsoil.
Yet, if it's extended interval service the OP wants, and isn't pushing past 10K...he has to pay for one of the best oils at that(Amsoil) unless it's just an engine/application that is super easy on oil and any syn can make it. Back to square one, having gone full circle, he still would have to see how any oil holds up to 10K before just blindly hoping it's working as well as Amsoil.
*See my previous post.
Originally Posted By: johnnydc
Not to slam Amsoil, They make great products. But you can go to Wallyworld Buy most any synthetic oil and filter foraround $35 or so. Why spend $65 on an oil change. Even if you're a PC you still have to factor in the shipping cost. Just my 2cents.
That would involve me going to wallyworld, which I'd rather not do.
If I have to worry about $65 a year I need to park my [censored] vehicle, because I obviously can't afford to actually run it. [censored], I spend $65 a month on my ezpass bill.
In every instance where I tried something other than Amsoil and then switched back I found that I got either a smoother running engine/trans, or less oil usage per OCI using Amsoil. I previously tried M1 EP 5-20 in my f150 for about 6500miles, far less than they state ( and I was using an amsoil EA filter)its good for. The truck needed over 3 qts top off over the period. Immediately following this I switched to Amsoil 0-20 100% syn with an EA filter. I'm 5K in and I've added 1/2 qt top off. I'm not saying Amsoil is the "power and the Glory, AMEN", but I've had great experiences with it, honestly better than any other synthetic I've tried. Put it this way; All of the money I spend on insurance, gas, tolls, and everything else that comes with car ownership I'm not going to pull up short on perhaps the most important thing I can do to keep my vehicles running well. Especially when for me its cheaper. I know I'm not going to get the miles/months out of M1 that I do Amsoil. I frankly don't trust it to make even amsoil's severe 15K recommendation. Not to say it isn't good enough for some at a lower oci. But I can change my oil once a year with amsoil and not sweat it.
My accord has over 378K miles and I have used just about every oil out there and every kind of OCI. MOST of it was done with Dino supertech, PYB, MC5k, Castrol gtx, and some QS. since I now do mostly highway miles at full temp, and a lot of them, I now use M1 EP only for the convenience of not having to change it as often. I am going about 10K OCI for the accord but our durango does so many short trips (less than 2 miles for kids' school) that I have switched back to shorter 4-5k oci's and PP or PYB depending what's on sale. My rule of thumb is shorter trips = shorter OCI's and use any oil that has a good VOA and UOA reputation. heck, 3 to 4K oci's with supertech and some of the "not so good oils" got me over 300K miles
All oil's have Cleaning Additives and Anti-Wear Additives, some oil's have more anti-wear additives while some oil's may have more cleaning additives.
Actually, from my experience, it is the total opposite, if your engine is dirty then your oil will have a harder time flowing through your engine and parts will either get worn out quicker or start making strange noises.
It sure does, but if you run into problems because your valvetrain or other parts of your engine is dirty, then you may have a different opinion. Time and miles will only tell.
The Amsoil Motor Oil's that are recommended for extended drains seem to have more anti-wear additives, if it really had more cleaning agents then the oil would probably have to be changed sooner. JMO
That really depends on your driving conditions, I hope you are basing your opinion from experience. Everything I have posted has been from my experience over the years.
