Originally Posted By: tribocessive
don't some of the experts say that once you lose 2/3rds of your original TBN it's time to change your oil? then there's this thing about high-ester based synthetic oils giving you a high TAN; still trying to make sense out of it all.
Well, that seems to be more straightforward advice; basic, and probably best when applied to conventional oil.
However, that is just my opinion based on reading here for a couple years now. Some of that can be associated with base oils, additives that may affect initial TAN for example. (for one that relies on changing oil once TBN falls below TAN)
If 'all things' look good in the UOA, running the TBN of a full synthetic down to 2 consistently(as per the Black Stone method for testing TBN) will not harm your engine in any way. It would take things such as a clogged PCV system but it's only an indirect way; needing fresh oil to 'mask' by keeping clean the issue of running the OCI out.
Yet, the whole point is to show that other information would likely also start to show itself such as insols before any serious depositing were to accumulate. And again, that would be as a result of something that is affecting an extended OCI; aka a troublesome application.
OR hopefully the purpose of the UOA in general, monitoring for potential problems, is thus accomplished.
