>>>Foam Air Filters that degrade and crumble within 2 years,
Since AMSOIL put the foam filters on the market, the only ones I've seen that crumbled within a couple of years were in cars with some mechanical (usually EGR) problem--usually GM. I recently put a new one in my Dodge van--old was still serviceable, but had been in use 3 years in old van and another 4 years in current.
>>>Auto Trans fluid that meets both GM and Chrysler specs (totally different frictional coefficients)
Fact is it has been tested against the requirements and passes with flying colors--verified by Lubrizol. Also does Ford Mercon and Mercon V, as well as a couple more.
>>>Propylene Glycol antifreeze (they jumped on the bandwagon when it was the "environmental thing to do")- overpriced and not recommended by many automakers today,
Actually came out before the Sierra. Yep, it is a bit pricey. Some truck lines buy it by the 55 gallon drum, because if they have a spill they won't get socked with a hazardous cleanup bill.
Some marinas use it for the same reason--they can dump it in the water without the water police fining them. As far as not recommended--how many decades was synthetic available and not "recommended" by automakers? And still not???
>>Windshield Protectant that isn't any better than Rain-X
Guess that is in the eyes of the beholder. It isn't a high volume product, but I know one trucker that found it much better than Rain-X in misty conditions.
>>>a whole range of Motor Oils that claim 25k or 35k change intervals (not)
Rcommendations based upon thousands of oil analyses. I've run it that way myself for over 25 years with nary a problem. Note that the recommendation is for non-diesel/non-turbo engines in sound mechanical condition. The time limit is also a year, without oil analysis. Obviously, some common sense is also required.
>>Might want to throw in the vitamins and fertilizer while we're at it!
Tried the fertilizer? Some commercial growers have found it to be very good and cost effective.
If you think selling synthetic lubes is difficult, try to learn enough to be able to be conversant in organic fertilizers.
