harry j
![[Linked Image] [Linked Image]](https://www.bobistheoilguy.com/forums/attachments/usergals/2020/03/full-10596-42799-img_0006.jpg)
I'm just wondering, do you think gas in the oil has cleaned out deposits, fouling the oil? I have never had a problem with the particle counts before.
That’s awesome. How long have you been running the dual filter mags?Miles on Civic - 582,138 / 936,860 km
Miles on oil - 7,090
Amsoil 0W-30 Signature Series AZO
Amsoil Ea15k20 oil filter
Twin Filtermags CT3.2
Dimple magnetic oil drain plug
AFE Dry Pro S air filter
5 ozs Liquimoly
48 ozs make-up oil
Blackstone Labs; Ah, it's great to find an improvement in the flashpoint. This sample flashed at 360 F, translating to
1.3% fuel, not a cautionary amount, so that helps quell concern over a fuel system issue. Metals are good as ever,
revealing no troublesome changes in wear. It's interesting that this oil was too dirty for us to obtain a Particle Count
(just to verify we ran the sample twice), but that's of little consequence. The oil filter was keeping insolubles low and
the oil itself still worked well (and held up nicely based on the normal viscosity and a 4.0 TBN. All told this engine
still looks fantastic.
Aluminum-----4-------------4 (universal average)Code:
Chromium-----1------------1
Iron--------------15----------9
Copper----------2-----------3
Lead--------------0-----------2
Tin-----------------0-----------1
Molybdenum----285--------89
Nickel-------------0-----------0
Manganese------0-----------0
Silver--------------0-----------0
Titanium----------0-----------1
Potassium--------2-----------4
Boron--------------66---------51
Silicon--------------8----------11
Sodium------------11---------42
Calcium-----------1361------2110
Magnesium-------1083------172
Phosphorus-------78--------713
Zinc------------------878------832
Barium--------------0----------0
SUS Viscosity @ 210 F------------59.7---------------------54-65(values should be)
cSt Viscosity @ 100 C--------------10.14-------------------8.56-11.9
Flashpoint in F-------------------------360--------------------->385
Fuel %------------------------------------1.3--------------------- Antifreeze%------------------------------0.0---------------------0.0
Water %-----------------------------------0.0-------------------- Insolubles %------------------------------0.3------------------- TBN-----------------------------------------4.0-------------------->1.0
Could possibly be the case here... Maybe the gas in the oil did clean.
Strange indeed about not being able to do the particulate counts.
Do you use the Liqui Moly to help quiet down the motor?
Like I have said before... This is one of the best long running threads on the board.
And it makes my 313,200 mile car look like a low mileage one still![]()
bbhero,
I started using LiquiMoly because I understood that it protects the cylinder walls, although it does make the engine
a bit quieter.
