Wanted to share the oil change I did on the supercharger (IHI) on my 2004 AMG E55 with the M113 5.4l V8 Kompressor. The car has done 180k km's and I believe an oil change was previously done. The supercharger spins up to about 20,000 rpm.
The supercharger has a little grub screw down the bottom and takes about 150 ml of oil. The oil is Mobil Jet Oil 2 which I bought for about $35 for a litre off ebay and was posted to me. Otherwise you can go to Mercedes and buy the oil for a gazillion dollars for 150ml.
Used a syringe and rubber tubing to extract the old oil and replace the new oil.
The oil that came out was crazy black and smelt really bad. No noticeable difference in sound since changing the oil out. I'm not sure what would make the oil go so black as it doesn't have anything to do with the engine oil. Would it be metal particles?
Here's a pic of old vs new. See if you can tell the difference
