- Joined
- May 31, 2024
- Messages
- 523
Alkaline batteries build pressure and start to leak when they're fully discharged.1) If it is a battery operated quartz wall clock movement, always change the battery on an annual basis. Do not wait for the clock to stop entirely. Set aside a fixed date, say every Christmas or New Year’s Day.
The key is to never let them get into that state.
"Alkaline batteries generate power through chemical reactions within the battery cell. These reactions create hydrogen gas, which is usually not a problem. If too much gas develops, the battery cell ruptures, releasing the white sticky substance we call battery acid. Under regular use, an alkaline battery will not leak."
https://www.betterbattery.co/blogs/blog/how-to-clean-and-dispose-of-corroded-batteries
