Am I the first one to get Edge 0w20!?? :D
Sarasota, FL
My good friends at AAP knew I'd be all over it so it's already ordered for me
This oil is gonna go with a Bosch DistancePlus in my SpecV once I drain out the edge 5w30... lately it seems that filters become more efficient with use, and the Bosch DistancePlus seems to flow better than the PureOne (someone here did a test), so the bosch it'll be..
I bought two Bosch Distance Plus 3323... one of them is for my G35, that car is a PAIN IN THE *** to change the oil, so screw it.. I'm gonna put in some Mobil 1 Extended Performance and let it be.
Meanwhile..I cannot wait to put on the Edge Ow20!!
BTW, those numbers under castrol edge, are the part number... it does not show on their system yet if they search for it, so if you want to order some 0w20 from the store, write down that part nunmber and give it to them.. it WILL show up if they manually type it in.
Originally Posted By: Nayov
In the Sentra? Calls for 5w30
A 210hp SpecV that gets autocrossed, rallycrossed, and drag raced.. it has no balance shafts, solid mounts, and it has been hit twice... and at 90,000 miles it's still one of the few completely trouble-free SpecVs ...call me a nut case, lol
Originally Posted By: CATERHAM
Yes I'd say you'll be the first to use the oil.
So when can we expect the used oil analysis?
My Castrol EDGE 5w30 only has 2500 miles =/ I put 2000 miles a month on this car, I'll drain it out early just not sure how early and then use the 0w20.
So estimate 4 months (i'm gonna be overseas for 2 weeks) for a used oil analysis... in a car that kills oil.
