alternative to PH3387A
I use the PH3980. The PH3387A is the Fram equivalent of the AC Delco PF47. The PF47 is recommended for my 4.3 equipped GMC van. GM used to recommend the PF52 for this engine, which crosses to the PH3980. I figure the shorter filter is probably adequate, but the longer one is much easier to install and remove.
As others have indicated, the ph3980 (or other brand equivalent) is what you are looking for. But in all reality, the 3387 is plenty large enough for a normal OCI.
^^^what they all said^^^
I've used the PH3980/PF52 on my 2001 GMC Safari work van since its first oil change. Now has over 100,000 miles.
