How about a CX-30 Turbo ?!?Sounds like the perfect vehicle for your needs.
They recommend 10W-30 in the Summer and 5W-40 in the Winter for a truck that you're supposed to use for work, heavy duty stuff. I would use 0/5W-40 in the Winter, depending on my location, and 15W-40 in the summer, most likely Rotella T6, as that's about the best Diesel oil you can get.
Lots of Zoom-Zoom.It would be close and come down to which car feels better to you since you are in it most of the day. The fuel economy of the hybrid is a huge factor. Gasoline is not going to get cheaper.
It would depend on how cold the winter is too, sometimes 15w40 can be used year roundThey recommend 10W-30 in the Summer and 5W-40 in the Winter for a truck that you're supposed to use for work, heavy duty stuff. I would use 0/5W-40 in the Winter, depending on my location, and 15W-40 in the summer, most likely Rotella T6, as that's about the best Diesel oil you can get.
Hard to say. Plenty of engines with just as tight of bearing clearances run with xW-50 oil and have no issues. Look at all the motorcycles that rev to 11,000+ RPM running xW-50 oil. Just because a few S2000s supposedly blew-up because of using 50 doesn't mean 50 is bad for every engine. Could be there is something about the oiling system that doesn't play well with 50 at WOT and high RPM for miles on the autobahn. Was there any oil pressure and temperature data given on these cars running these top speed runs?We had these one here posted numeroeus times, if i remmber correctly? Are the datas fom this blog feature doubtfull?
https://blog.k1technologies.com/bearing-clearance-and-oil-viscosity-explained
When i compare these datas with the bearing clearances honda gives in the S2000 workshop manual, hondas reccomendation of a -30 oil is spot on. And Honda has a long heritage an expirience with high reving engines.
Only if the oil is too thick to make it to the inlet and be pumped by the pump. That's why everyone should use the correct "W" rating for the ambient conditions the car is used in.Might he be concerned about oil starvation?
Excuse me? This sounds like you guys have other problems besides 0w-20We have not had any engine over 2 liters go over 60K with 0W20. And that was using Premium Oil and filters changed at factory intervals or better. I'd have to look at records but that was four down.
Most cold start wear is due to corrosion (from water vapor) and engine part tolerances being out of spec. Not a myth, just not due to oil.Cold start wear is a myth, there is more than enough MOFT from any oil at a cold start to prevent wear.
Just like every study I've see, thicker oil gives more bearing MOFT. If a bearing becomes damaged or fails when running thicker oil it's because of a lack of lubrication, not due to the oil viscosity.
Low oil is the main cause of this. At high RPM it can suck the oil pan dry and then it's goodbye engine.Just like every study I've see, thicker oil gives more bearing MOFT. If a bearing becomes damaged or fails when running thicker oil it's because of a lack of lubrication, not due to the oil viscosity.
Yes, another possibility. Many manuals say to add a quart of oil for track use conditions.Low oil is the main cause of this. At high RPM it can suck the oil pan dry and then it's goodbye engine.
Were they all Ford engines?We have not had any engine over 2 liters go over 60K with 0W20. And that was using Premium Oil and filters changed at factory intervals or better. I'd have to look at records but that was four down.
Even regular car manuals that don't specifically recommend higher viscosity state that under extreme conditions a higher viscosity oil may be required.Yes, another possibility. Many manuals say to add a quart of oil for track use conditions.
When oil is at full operating temperature, the difference in viscosity between 30, 40 and 50 isn't big enough IMO to cause a major change in flow with a PD pump that would "starve" bearings. If there is an inherent oiling system flaw, or maybe an oil filter thats too flow restrictive for constsnt high RPM, then that could also be a factor. What if these couple of cars that smoked the bearings were a bit low on oil?
If thicker oil was causing bearings to fail, then no manufacturer of high performane cars would say to use a thicker viscosity for track use.
They’re actually recommending 10w-30 year round in all new 12L coach buses and efficiency series 15L semi engines now. Haven’t seen any oil related issues yet. That being said, most truck fleets still run 15w-40 year round and buses don’t get shut off for long. 5w-40 I think is the sweet spot year round. I’ve used that in all my Cummins, Powerstroke, or 80’s Mercedes diesel engines I’ve had. Ran it in New Mexico/Arizona summers and some Canadian winter trips.They recommend 10W-30 in the Summer and 5W-40 in the Winter for a truck that you're supposed to use for work, heavy duty stuff. I would use 0/5W-40 in the Winter, depending on my location, and 15W-40 in the summer, most likely Rotella T6, as that's about the best Diesel oil you can get.
Yeah, and they run gallons and gallons of 15w-40.@Accent Abuser it doesn't have to be a high-RPM application, just think of high horsepower Diesel engines.
