All You Guys That Think OEM Recommended 16 or 20 Weight...
Do any of you remember when ford began specifying 5w20 in their f150's and they started dying due to increased stress and the oil not being able to handle it due to old oil system? 5w20 has gone a long way though since 2001.
I'm running 10w40 in my 2002 Ford Escort that's spec'd for 5w20. I don't know what the previous owner ran in it but I bought it at about 80K miles, it's now got over 210K and is doing fine. I ran 10w40 in my '88 Escort that spec'd 5w30 and retired it with engine compression 145-155 PSI across the board at 518K miles.
oil is too thin and want to move up to a 30 or 40 weight oil for "better protection" might want to consider this:
"Contributing factors that can cause oil pressure and lubrication problems in an engine include:
5. Bearing clearances too tight for the oil viscosity being used. Late model engines such as a Chevy LS or Ford modular V8 with tighter main and rod bearing clearances of .0015˝ to .002˝ usually require a thin multi-viscosity motor oil such as 5W-20. Fill the crankcase with a relatively thick racing oil and you’ll have problems right from the start. Tighter bearing clearances require thinner oils..." https://www.enginebuildermag.com/2017/03/engine-bearing-technology-spin-spun-bearings/
Wait until the author realizes there are four seasons and what happens to oil during winter.
AFAIK, Dexos2 is the “Euro” GM spec that’s for their Opel/Vauxhall/Saab gassers and their “passenger car” diesels based on ACEA Cx specs. dexos1 is strictly a gasoline engine standard based on the current API/ILSAC standards for gas engines for GM North America/Holden/Daewoo/GM China IIRC.
Just so. Here in the US, Dexos 1 is gas and Dexos 2 is diesel, but Dexos 2 is gas in Europe as well as diesel.
No correctly designed engine oiling system is going to starve bearings when the oil is at operating temperature and the pump is in pressure relief. Why do you think the pressure relief is set to a high value? The difference in flow at pressure relief between xW-16 and xW-50 at operating temperature isn't going to matter. If it did, all those Boss 302 Mustangs running 5W-50 would have blown-up on the tracks all across America. And besides, a PD pump is going to be more efficient with a thicker oil due to less rotor slippage (ie, less oil leakage at the rotor tips).
I did not mention inadequate lubrication at bearings, I was discussing the critical bore lubrication through oil sling off the rod big ends, Though if you extend this to a logical extreme you WILL starve bearings with a certain high viscosity due to inadequate flow presentation. This would be likely COLD oil and Cold coolant / engine temps and extremely high viscosity in the sump.
I have not seen it discussed that many races engine use high viscosity oil but it is dry sump and often PRE-HEATED
Also 50 grade after adequate warmup is not excessively viscous for even under 0.0010 radial bearing clearances, though care is taken in how the oil is presented to the bearing through elliptical journal orifaces and other shell modifications. There has been much trial and error in the past before flow could be modeled with more widely available "affordable" supercomputers and associated software.
The Track was quite the proving ground for new ideas. "Race Proven" is not just an empty tag line :)
5w-20 is fine if you drive like a grandma.
Of If you have an engine put together better than a Hyundai :)
I LOVED my 1995 Accent. The best Hyundai I owned over this, an Elantra and a Sonata - all manual and all wailed on.
Hyundai was using Porsche in the development and this made for a very capable and fun to drive buzz bomb
1994-1995 was when Hyundai was seeking a reversal of their fortunes - and over 20 years later they did well. I think that Elantra was the first to be in-house developed at Hyundai with little/no help from Mitsu. Before then, all of their efforts are rebranded or somewhat changed from Mitsubishi engineering and design.
The wife's 2012 Elantra 1.8 has done fine so far on 5w-20 for 115k miles. She drives it like an F1 car, don't think it sees much under 3k rpms except at stop lights. Other than brakes, a VVT solenoid, and a belt, haven't had had issues. Trying out QSFS 5w-30 this oci though, just for giggles. It's about the same at startup, maybe a bit noisier actually, even she has commented on that. But it is a tad quieter when hot. Otherwise not much difference. Going to try M1EP 0w-20 next oci and see how that goes, will be just in time for winter I think.
As in all the past discussions about oil viscosity, as long as an appropriate "W" rating is used for the ambient use conditions, lubrication of all parts should be adequate ... even for bore lubrication by way of rod big end oil sling-off. As a dumb kid, I had 20W-50 in my Ford 289 and fired that thing up in the winter when it was so cold the engine could hardly turn over. I never saw any ill effects, even though a 20W was too thick for the temperatures I used it in.
The example I gave of the Coyote V8 specified to run 5W-50 in the Boss 302. The Coyote has been around since it was first introduced in 2011, and I highly doubt the journal bearings are anything special as they can run anything from 5W-20 to 5W-50. The Shelby GT500 also called for 5W-50.
Wow….
Those “modern” engines have the same bearing clearance specifications as the 1932 Packard.
Not that tight, in other words.
All of that “designed for thinner oils” and “modern manufacturing” talk appears to be just talk.
The proper viscosity for a given application has far more to do with operating conditions, including temperature, than engine clearances and manufacturing tolerances.
You forgot CAFE requirements.
So I made a phone call to get confirmation on this. Some of the teams will change to a lighter 0W-5 or SAE 0 oil just for qualifying. They put in a 0W-16 for actual race.
Well technically there is no SAE 0 grade right? Since there is no such grade defined by the SAE.
Those "thicky" NASCAR guys ... 😄
It's still fun and capable 🙂. 138hp and a very responsive 6spd auto goes a long way in such a lightweight vehicle. The engine sounds like a rattle can on the specified 5w-20. It's nearly silent at idle on a 40 or 50, and much quieter and smoother at high RPM. Do what the engine doth protest the least is my motto. If I had a Toyota that purred like a kitten on 0w20, I'd probably stick to that.
Honda S2000. The 9.000 RPM F20C engine: Owner manual calls for 10w-30.
The last two reports of damged engine in the german S2000 Forum had two things in Comonn:
Trying to reach top speed on the autobahn and both engiens where filled with a 5W-50 Oil "For better protection".
Co-Worker is 100% Alfa Romeo fan. When he was younger, he followed advice from friends and used 10w-60 in his Alfa Romeo instead of -40 as recommended in the manual, because "These are such sporty engines, constantly high reving.." The engine had a Bearing failure in short time.
Since this time, he uses the Viscosity that the manaul calls and the engines last.
In the german Liqui Moly forum was a thread that looks like trolling: One guy has owned one Opel and two Skoda (=VW) , theses engines where specd for - 40 Oils or thinner. He reported that he used 10w-60 Oils for better protection becasue the engiens where "Tuned" and that he used the cars on short trips around town. All three engines died from bearing failure in short time.
https://forum-liqui-moly.de/index.php/forum/motoroele/1242-motorschaeden
(Use Google translator)
And if they told you that wolverines made good house pets would you believe that too?
