I discovered a tear in one of the rubber couplers on my intake about two weeks ago while under the vehicle. I had noticed that my intake air temperatures were reading high on my datalogs (I tune and datalog with Hondata's Flashpro). Intake air temps were on the order of 30F above ambient vs. about 10F when I know my intake was working correctly so I was sucking considerable amounts of air off the back of the radiator through the tear.
I fixed the problem (Kudos to AEM for sending me a replacement part right away on their dime when this problem was likely my fault) and drove the car about 15 miles to completely warm up the engine and then dropped the oil since I was seriously concerned about what kind of damage could be done while injesting all of this unfiltered air. The results of my latest UOA are NOT what I was expecting. Trending seems to suggest that the intake leak may have started fairly recently, within the last 10,000 miles or so. I installed the intake at around 19,000 miles but with silicon being relatively low and not rising at all between the last two samples (both from the same oil run) I'm not sure what to make of it.
The sample taken at 30k miles was in response to the discovery that my datalogs were showing some knock so I wanted a baseline to see if lead dropped after I adjusted my tune to eliminate the knock. Instead, lead read higher than it ever has so I'm not sure what to make of that. It could be that sucking all of that hot air with the intake leak was resulting in the knocks I was seeing and the extra shock on the bearings was throwing the extra lead. It could be that extra grit in oil from running unfiltered air wasn't nice to the bearings. I'm at a loss. Wouldn’t there be other indicators such as copper or tin to go along with the lead if it was from the bearings? All of the other metals have been very, very low so is it possible that the lead I'm seeing is from some other source such as fuel?
With regard to silicon not changing between samples with the blatant air leak is it possible that most of it is picked up by the oil filter before it causes a serious problem? I’ve been using Pennzoil Platinum 5w-30 since the first change with the past three changes and the current run bought at the same time (not sure if they were all the same lot). Oil filtration is a Purolator Pureone.
Thoughts?
Picture of the split in the intake coupling. The gap was about 3/8" when I discovered it. I had the joint loaded in one direction which caused the tear over time.
Thoughts?
