The vast majority here are obviously going to have central heat/air. For those of us in old farm houses like myself without that luxury (and several cats/dogs running around), I'll share what I did. You'll need....
Box fan - The basic/cheapest versions you'll find won't work, as they're too noisy, and too small. Here's what I went with:
https://www.walmart.com/ip/Lasko-20-Performance-Weather-Shield-Box-Fan-B20500/19861418
Only $23. It's a little larger than the basic 20" models, and significantly quieter (lower fan rotation speed, but still moves plenty of air).
Filter - 20"x20"x1" filter, which you can find anywhere. I've settled on the Filtrete 1200 MPR (MERV 11) w/activated carbon:
https://www.walmart.com/ip/Filtrete-Allergen-Plus-Odor-Reduction-Filter/37532015
They're around $13. Just attach to fan with some tape. I've been blown away by how well they work (this is after several months)...
Oil - Whenever you change the filter, you also unscrew the front cover, pull the blade off, and put a couple drops on the bearing. One $3 bottle will last forever:
https://www.lowes.com/pd/3-IN-ONE-3-oz-3-in-1-Electric-Motor-Oil/1210103
Have a couple of these fans running 24/7/365, only being turned off for filter changes. Have over 15k hours of operation, and both still run like new.
