Battery Minders are a bit confusing about their applications though.
They advise their AGM algorithm is only for Odyssey, Optima, Yuasa and other "high performance" AGM batteries.
For most common plate type AGMs (Interstate, Varta, Clarios, Walmart, East Penn, AC Delco, etc.) they recommend using the flooded setting.
I'm using a Battery Minder 2012AGM on an Interstate plate type AGM for over two years without issue...so maybe it isn't that big a deal. It does not appear to overcharge it, and hasn't been detrimental to service life...yet. But I am using the flooded setting on my Battery Minder 128CEC2s used on my other cars with plate type AGM batteries.
On the 128CEC2 the actual markings on it state "Odyssey/PLT (pure lead tin)", then "Wet/AGM/Sealed" then "Lithium".
