I recently bought a new X2 Power group 35 battery in the mazda. The OE battery only had 125 CCA according to the tester and it barely started my car.
I've had a few days off so I have been messing with it. I took a measurement of the battery yesterday around noon. It was 12.5v. I could see that as I had started it the night before just to move it into the garage. Later in the evening I went to clean the interior but I decided to hook up the charger. Its a NOCO Genius G3500. I took a voltage reading before hooking up the charger and it was 12.35V. Seemed kind of odd but I hooked up the charger and got to cleaning the interior. I checked after cleaning and it turns out if the interior lights are on the charger won't really do much. It was still flashing the 25% light and the voltage was around 12.5v. As soon as I closed the doors and the dome lights went out. The charger voltage started climbing. It rose up to 14.6V until the charger started to flash green 100%. It dropped down to 13.something and I left it over night. I checked just a moment ago and the green 100% light is solid. I turned on the voltmeter and its still pumping out 14.4V. Seems kind of odd. Should this be the case? I don't want to ruin the battery with a faulty charger.
20181125_120728 by JOHN, on Flickr
20181125_120604 by JOHN, on Flickr
