Hello Gents,
1992 corvette put a new Napa Legend in it in June, I don’t drive the car much maybe 1k a year.
Drove it a little and it sat for a month and a half. Took it out last week and went for a ride no problems. When I got home and was inside for a while I noticed a small puddle under the battery compartment on the ground. I went out and removed the battery and it was leaking from the vents on both sides. I cleaned up the mess with some baking soda and water.
I was able to get a new battery under warranty, my friend who is a mechanic came over with a battery tester and volt meter, the battery was installed the charge said normal on the battery tester. We then put it on a volt meter it said 14.5 then went down to 14.2 to 14.3 after it warmed up for a while. The same reading my digital readout was giving me in the car. I then drove it for an hour came back and checked it on a voltage meter again it said 14.2 the same as the cars readout said.
Today when I checked the oil, I noticed acid was coming out of the vent, not as much as before, but it was starting to form in the tray, I removed the battery again.
Guys any ideas, I will replace the alternator, but it is charging at 14..2 when warmed up 14.6 cold start and 13.9 at night with lights on. I don’t believe I would get 2 bad batteries (new)
Thoughts,
Thanks,
Dan
Thoughts,
Thanks,
Dan
