- Joined
- Oct 16, 2023
- Messages
- 270
My 91 d150 5.2 has an integrated ecm controlled voltage regulator. It is failing. So I figured I’ll install a voltage regulator externally and by pass that ecm garbage. So I cut the green wire which is ecm to alternator and took the blue ignition wire wired it to the voltage regulator and to the alternator. The other side of the alternator I went to the voltage regulator. The battery + wire is still factory and hooked up to the alternator and I have the factory ground attachment wired to the alternator body as well. It doesn’t charge. If I take the ground side of the wire off the regulator and ground it to the alternator it will charge and full field the alternator.
When the truck is running I have power on both sides of the regulator but only battery voltage (not charging voltage. I followed this wiring diagram so I’m unsure what I did wrong. Any help is appreciated.
