All,
I put a set of 18 inch Veloster OEM wheels on my sonata with new tires from discount tire.
The guys strongly advised me to get new TPMS sensors because the OEM sensors are from 2011 and they typically only last 5 years, and the batteries are non replaceable.
I said nah no thanks, and then he said it would almost cost the same in labor to rebuild sensors, and remount them than to just purchase new ones.
So I went with the new sensors, purchased 4 new tires for $495. He cut me a deal on everything and they were fair about it.
Anyways I have had to take the car back three times so far for TPMS light blinking, then staying lit.
First time the guy said oh well you may have some interference from the old wheel tire assembly being inside the car when we scanned. So I gave him that, and he reprogrammed the TPMS again, and the code came back 1 hour later.
So today I go back, and the guy says yeah must be interference, let us try it again, and if not we will replace all 4 sensors.
Sure enough it lasted about an hour and the light came back on.
So I'll drop the car off next week.
My question is this, has anyone had troubles with aftermarket VDO brand sensors. Also do they have to be programmed to a certain tire pressure, or is one vehicle setup for one tire pressure only?
The 16 inch factory wheels were about 36psi, and the new 18 inch wheels are the same, so the pressure is not low.
Anyways car looks great, but the weather has been terrible, will post photos when i get it cleaned up.
