As requested, the following:
The box of the TPM Quickset says to visit
www.tpms-tools dot com or email tpms at atequsa dot com for further information. The instructions in the box and the graphic instructions printed on the box were sufficient for me.
This is a pc based interface where you can save the summer and winter sensor IDs on the software. All you do is upload the specific ID info into the car's ECU to install or reset with the supplied connector. The connector is detached from the pc after you feed the specific info to it. So it is a small device taken by the installer to the car.
I had read prior of Tirerack selling them but am guessing they had too many returns and no longer sells them. I purchased mine from an online vendor. If you can use an OBD II scanner and reset the check engine light after retrieving trouble codes, you can do this.
At $90 to install my four wheels and reset at the Honda dealer times twice a year ($180) , this purchase ($150) is worth it for me. Pays for itself after one year. And I do not need to make an appointment nor put up with the upselling. The other part of this is having a full changeover of winter wheels with TPMS which can be a significant purchase.
This is a specific TPMS tool and just updates the car's ECU of TPMS IDs.
I do understand some folks do not have the time and/or patience for vehicle maintenance. For this vehicle, I have installed a Fumato valve for easier oil changes, changed out differential fluids, transmission ZW-1 fluid and installed the Honda fog lights courtesy of YouTube and the paper instructions.
