Probably borrowed instructions from a procedure that requires coolant drain/refill.
#7 says charge refrigerant (if it has been collected)
if you arent touching that you just skip.
This is for FB25 with TCV (not thermostat)
I used a Lisle radiator funnel when I did the flush and fill on my wife's Outback. It worked pretty good.
Yes it has to be engine off because you are flooring the acceleratorGreat, to clarify, the first part of the procedure is ignition on, engine off?
unknown without a model year.Does that vehicle have the TCV instead of t-stat? This TCV thing is new to me.
I’ll tell you from experience on the EJs it takes a long time, 20 minutes or longer in some cases. Try to have the front of the car on ramps or in the air to aid the bubble removal.Any link by chance to good procedure or would filling with the Lisle tool be sufficient?
@panthermike please note that procedure still says to use the Subaru Coolant Conditioner.
It’s right in there… guess not.Oh darn I thought they did away with the conditioner after 2010 MY or so?
It gets confusing, in newer engines or engines that have the original HG replaced with MLS, Cometic/ Six Stars the conditioner (Holts stop leak) is not necessary. I guess Subaru needs to unload large stocks of this product.Oh darn I thought they did away with the conditioner after 2010 MY or so?
Subaru models, especially those with newer EJ25 or FA20 engines, the Subaru Coolant System Conditioner is no longer necessary. The conditioner was initially used as a "band-aid" for head gasket issues in older EJ engines, but newer engines and gaskets have improved
Cometic Gasket MLS (Multi-Layer Steel) head gaskets typically do not require additional coolant conditioner or sealant. The gaskets are designed with a .001" thick Viton rubber coating bonded to the outer stainless steel layers, which provides the necessary sealing without the need for additional sealers. Adding additional sealers or coatings can hinder the performance of the gasket
Very helpful, thank you sir!It gets confusing, in newer engines or engines that have the original HG replaced with MLS, Cometic/ Six Stars the conditioner (Holts stop leak) is not necessary. I guess Subaru needs to unload large stocks of this product.
That is a very long time to be running with large air pockets in the cooling system — it can cause damage to the head gasket.There was a ridiculous amount of air in the system that took about 15 to 20 minutes to resolve. After about 20 minutes and several short burst of raising the RPM, finally a really large amount of air released and The heat started blowing hot.
For comparison, I performed some cooling system repairs to a FB25 last weekend — both thermostats and water pipe o-rings. I vacuum filled the system, filled the coolant funnel with a small amount of coolant and followed the factory procedure for bleeding. Started up, revved to 3K several times, shut down, topped off 4-8 oz. Repeated once more. On the third startup, level in the funnel remained stable and heater was blowing warm within minutes.
That’s going to make such a mess. You’ll have to rinse the engine bay afterwards or else customer will be complaining about coolant odor for days.If you pop this hose off the throttle body when filling you will most of the air out, when you see coolant there put it back on.
Why is Zerex preferable to Peak?No don't do that. Supertech is supplied by Prestone. Prestone includes 2-EHA even in their Asian coolant. Asian coolant should not contain this. Get Peak or, preferably, Zerex.
