Yes, just two times. I had a rough time installing and mostly removing because the engine sensor is in the way and the HiFlow if I remember correctly is a little bit wider. Of course also the HD oil filter tool does not fit it.Has anyone used a HiFlo Filtro HF171B RC on a 103 or any other of their filters on a Big
Twin?
The H Flo has a nut welded on the end similar l to k&n.Yes, just two times. I had a rough time installing and mostly removing because the engine sensor is in the way and the HiFlow if I remember correctly is a little bit wider. Of course also the HD oil filter tool does not fit it.
I can not say for sure but in my mind, I felt as if I had more engine noise at start up for a second or two. Almost like after you change oil, the tick noise but for a shorter period. I questioned to myself if the bypass valve was not in spec.
Anyway, I gave up, the HD filters are great but have become more than pricey, I found some Wix that I have tried, was happy with it, nope HD filter wrench does fit that either but I mange, thing is the next two that I ordered both at different times came in dented. Gave up on them. But nice filter and feel it's more specific to match the HD filter specs.
So, just for fun, for the first time ever in 9 years I put a Fram on it. Doubt it matches HD specs but it's a filter and zero start up noise vs the HiFlo. I just installed the Fram about a month ago and I am ok with it, whether I continue I'll figure out in the future. Most likely I will continue. Had a great ride yesterday temps hit 70, rural roads and then to the beach.
Whip City Wrencher did a comparison video of a Harley filter and a regular Hiflo non-RC filter.
Ok, guess I should have paid more attention to the Model # you are talking about.The H Flo has a nut welded on the end similar l to k&n.
Twin?
Not sure of your reply as to who but if it matters its largely rumored K&N is made by Hi-Flo. Adding to the rumor is K&N motorcycle filters are made in, yes, same place as Hi-Flo Thailand. I'll leave it to that.Looking at their website,they’re made in Thailand and TUV approved. They appear to use premium quality suppliers.
You know? For years now, just not motorcycles I always wondered if the louvers (or the stamped holes) ever restrict. I am sure they are fine but Im back in the camp of preferring the plastic cage if given the choice. I dont stress about it, mostly*LOL*This “dire warning” has been covered it’s not unique to HD and has been seen in various brands.
FWIW the last couple SP5 I have seen have had excellent louvers.
I've calculated the pressure drop across the centre tube of a louvered PurolatorOne filter using an online pressure drop calculator. It worked out to be on the order of 1% of the total filter dP. The inlet holes on the filter base were a bit more restrictive at 2% of total dP. So almost all of the restriction is from the media, and the centre tube is hardly going to restrict flow unless maybe it's defective and most of the louvers are closed, which can happen.You know? For years now, just not motorcycles I always wondered if the louvers (or the stamped holes) ever restrict. I am sure they are fine but Im back in the camp of preferring the plastic cage if given the choice. I dont stress about it, mostly*LOL*
Good post.I've calculated the pressure drop across the centre tube of a louvered PurolatorOne filter using an online pressure drop calculator. It worked out to be on the order of 1% of the total filter dP. The inlet holes on the filter base were a bit more restrictive at 2% of total dP. So almost all of the restriction is from the media, and the centre tube is hardly going to restrict flow unless maybe it's defective and most of the louvers are closed, which can happen.
@Rob C
I am not typically a YouTube person but you cant deny the actual photos. This is freaking scary and I was a proponent of HD filters in the past... I think I may just stay with Fram but either way, just look in the filter.
