Originally Posted By: Trav
I didn't even bother look at mineral oils and i can see that it might be of some benefit to them. They do use it in one semi and not in any of their full synthetics. In their full synthetics they use a different moly called molygen not MoS2. Whats up with that?
Dunno. It might be organic moly - liquid stuff. Allegedly, that's what is used in Schaeffer's Supreme motor oil (which has a moly level per that is off the charts, per VOA)
Don't misunderstand me i am not calling it snake oil because it definitely isn't. I just think its an old school additive that worked well with the oils of yesteryear and has no place in a fully formulated modern oil especially a full synthetic.
I'm not so sure about that. All you can say for sure is that major oil companies are not using MoSw at this moment. But several factors have changed. Air cooled engines are not the rage. Oils (including synthetic oils) are much better. Organic moly is now available.
My best opinion/guess for non-use? MoS2 turns your oil black - that is simply a non-starter in the marketing department, and that trumps just about everything else. BTW, the 'turns your oil black' is a simple way to know if an oil or additive contains MoS2. Organic moly does not seem to do this.
In more civil days, I asked Molakule about the differences. As I recall, he opined that MoS2 builds up a substantial layer, really fills in around the rings (reduces oil usage), provides serious start-up and limp-home protection - and turns your oil black. Organic moly only forms a thin layer, perhaps one molecule layer thick. It does reduce friction, provides very limited start-up protection and no limp-home protection - and your oil stays an amber color. He also advises that a used oil analysis or VOA cannot differentiate between the two flavors of moly. I guess it just depends on the level of gunfire in your neighborhood (or if you drive a Forester with potential pick-up tube issues ;-).
Course they is no competing with the butt dyno, the placebo effect or some slick advertizing like microscopic ball bearings in a can.
Yep that sounds good to me, i buy Mobil 1 0w40 and PU for my engines then i adulterate it with some solid lube the folK who make the stuff wont even use in their own top shelf oils but i allow them to convince me i need it.
I was born at night but not last night.
Strangely enough, almost all of the oil scam sellers are hawking PTFE-based magic... not MoS2. Maybe they should be selling MoSw ;-)
For industrial use, MoS2 - black color and all - is used everywhere and has been for decades. It is in sumps, transmissions, differentials, hydraulic systems, greases, you name it. Maybe you don't really need it in a civilian vehicle, but logically, it should be just as useful in the family car as it does in a 5-ton M939. But, the latter vehicle has no OCI - they just do a used oil analysis and keep going - sometimes for 100,000 miles or more.
There was a funny anecdote on BITOG many months ago. Some person was recalling that he once use ARCO Graphite Motor Oil in his car. His father was looking at the dipstick and remarked: "Why would you use this oil? It has already turned black!"
Here's my variant on that story: I had a brother who was 'into cars'. Whenever he got ready to sell one, he always changed the oil and put in non-detergent oil. Potential buyers would always check the dipstick and smile because the oil looked so clean.
I drive a Forester and I live in a war zone. That's two reasons to make mine MoS2 ;-)
