An increased idle speed is a sign of a problem, not the beginning of a solution. Your Focus has electronics so sophisticated that any change in base idle would be compensated for so quickly that you'd never notice it unless you had a scan tool on it and was reading IAC counts before and after the addition of acetone in the exact same environment.
I recently cleaned up a really gunked Neon throttle body, and before doing so, had the scanner on it to see if the IAC was working. It was, but the passage was so plugged it couldn't flow enough air to properly stabilize the idle in gear. IAC counts were in the 70s idling in park before cleaning, and in the 40s after. The PCM responded immediately and the idle speed in park never changed. Either way it still idled at a perfect 725 RPM. Just that after cleaning, it would react to being put in drive and idle at a smooth 650-675 RPM.
