Here's probably a dumb question. If an oil has an ACEA approval rating on its PDS, eg. a dual rated SN oil with A1 or A5, but doesn't have the sequences year listed, eg. A1-2, A1-4 or A-8, are you to assume it is the lastest A1-8 or an early A1-2. There is a significant difference in performance rating between the earlier and later ratings.
Here is an example PDS http://www.castrol.com/liveassets/bp_int...S_april2011.pdf. The 5W30 lists just A1 and A5 approval.
