Patman
Staff member
Originally Posted By: webfors
Why is the upf64r not an option for you? Isn't the 22psi a minimum spec? I was considering making a case to use this filter on dealer oil changes.... in which I case I may consider running it longer.
Having that 35psi bypass setting bothers me, plus I don't even know where to get a UPF64R filter, either here in Canada or when I cross the border into Niagara Falls NY.
The Fram racing filter just doesn't appeal to me either, and even though they technically can't void your warranty, they sure can make things difficult for you when making a claim. I'd rather not give them any reason to try and fight with me if an issue were to happen. The PF64 makes life easy in that regard.
