Originally Posted By: WellOiled
Originally Posted By: webfors
Question: of all the filters available with the 22psi bypass spec, which one is the most likely to be of the best construction with respect to reliability. Meaning, which ones have we seen 0 defects/failures for?
There is no efficiency without the media staying in tact. Top contenders are:
Wix WL10290
Wix WL10290XP
ACDelco UPF64R
The UPF64R actually has a 35psi bypass.
Would this be a good alternative for the ATS, while keeping GM happy with respect to warranty? I may be able to convince GM to use this filter exclusively going forward as a result of my poor experience with the iPhone PF64.
Are there any good C&P of this filter?
If I were in your shoes I would consider the following:
I would choose WIX WL10290 or 57502. The efficiency is 50% at 6 microns and 95% at 20 microns. And enough capacity to go past the OLM. And a 22 PSI bypass setting.
During December, January, February, March and mid April you might consider a 0W30 Dexos 1 Gen 2 oil. Alternatively, put the ATS in the garage or put a sump heater on it.
I was planning to ask you when the oil and filter were installed and when they were changed as well as an idea of your driving habits. This along with the UOA may shed light on what to do next.
I’m thinking Cadillac will want to do some diagnostics to see if there is a problem that needs attention.
I hope Cadillac treats you well.
I like the Wix 57502. It seems to have all the right qualifications. However, poor pleating can still cause a failure.
Cadillac offers maintenance included for the first 4 years. I want to hold them to that for warranty purposes and also because I plan on selling the car in 5 years. Dealer service always looks good when selling. I suspect I can force them to use the UPF64R, even if it comes at a cost.
Another consideration would be an oversized Fram Ultra, specifically XG10575. More media = less chance of a bypass event even with the 9-15psi bypass setting. Reading over threads where the delta-p was provided by Fram for the Ultra media, it appears it would take cold weather and high rpms on a cold engine to cause a bypass event. In this case is the 22psi bypass spec relevant?
At this point I just want assurances that I won't go 5k miles again without filtered oil. A metal backed synthetic media, with construction like the Ultra, will almost certainly provide that assurance, regardless of the statistical outlier scenario of a bypass event.
Now, if someone can point me towards a Donaldson Synteq filter that fits my car, I'll go with that
Wix WL10290
Wix WL10290XP
ACDelco UPF64R
